stabilize top & tilt for mowing?
   / stabilize top & tilt for mowing? #11
Contact Mark Carter (CCI) at CCM (ccmachinery.com). He can answer all your questions.
   / stabilize top & tilt for mowing? #12
Don, there's a fairly cheap way to stabilize the tilt cylinder. If you use quick-connects at your remote valve, just disconnect the hoses. If it still leaks down due to the hoses expanding, put quick-connects directly on the cylinder.
Center the cylinder before disconnecting and reconnect after you finish. (Don't connect or disconnect with the weight of the mower on the 3PH because the fluid will be under pressure and you may not be able to get the connectors loose.)If it drifts with the quick-connects disconnected, the cylinder is leaking internally and a piloted checkvalve won't help that.
Of course, if you wanted to adjust the tilt for any reason while mowing, this won't work, but I rarely need to adjust tilt. I do sometimes adjust the toplink when cutting over the side of a gully or a pond.
Thanks Jim, I do have quick disconnects at the valve and will give it a try. Still waiting for those flowers to go to seed, won't be long now. /forums/images/graemlins/smile.gif
   / stabilize top & tilt for mowing? #14
My problem is that once one flower stops blooming and goes to seed, another flower pops up. I've got some gorgeous bluebells I've been mowing around, also lazy daisies, and dayflowers. I have mowed patches and unmowed patches just because I can't bring myself to cut all the flowers down. /forums/images/graemlins/crazy.gif
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
Trailmobile Van Trailer (A56435)
Trailmobile Van...
AUCTION STARTS HERE @ 9:15 AM (A58374)
AUCTION STARTS...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2013 John Deere 350G LC Excavator (A59213)
2013 John Deere...
