powerscol
I started a new thread on this as I believer I confused folks with the previous title that could be confused with a particular brand.
After doing a search I am somewhat confused - normal for me. Did a bit of plowing yesterday with the bucket as I always have done, and while OK there must be an easier way. I have the SSQA plate on my loader and two hydraulic remote connection up front (run from rear remotes) too to operate a plow blade (current use is my hay grapple) while still having full loader arm control (lift and tilt).
I'm am guessing that a 7' blade would fit, but have no knowledge how to size. I am assuming you calculate the width needed with full blade tilt and still be wider than the tractor. Is this correct?
While speaking of blade tilt/swing angle what is the minimum needed? Many have mention in other posts of needing at least 30 degrees or more. Most of the units I am finding are only 25 degrees of tilt.
What brands and models can folks recommend. I saw the Hiniker brand mentioned several times. Thier blades are not steel - is this an advantage? I see the Quickattach folks have one too but thier only got to 25 degrees.
What makes for a good plow set up over others? However I would still like to back drag my drive in front of the garage like I can with my bucket - will these plows allow this? I do have chains for all four wheels.
Thanks for any help.
Keith
Keith
