SSQA Plate Thickness For FEL Plow
   / SSQA Plate Thickness For FEL Plow #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
I'm picking up a nice used Western plow tomorrow to convert into a FEL plow. I see they have SSQA plates in different thicknesses and I'm wondering what thickness to go with 1/4", 5/16", 3/8", or 1/2"? I don't want to have to buy the 1/2" one if I don't have to due to a large price increase. I will be mounting this plow using the float method with a chain for now and mabe this summer convert it over to the down pressure method.
   / SSQA Plate Thickness For FEL Plow #2
You will never know if your plate is too strong. You will know when it is too weak. Your operating conditions and style will dictate the needed strength of the components you use. We can't answer that.
   / SSQA Plate Thickness For FEL Plow #3
The 3/8 should be enough but i would not mount the A frame directly to it without first running a stout piece of channel across the width of the ssqa plate, making the bottom basically a box beam .
Weld your mounting ears on the channel so you spread out the load .
   / SSQA Plate Thickness For FEL Plow #4
It would take way more than a CUT to bend a braced 3/8" plate. I built my lift pole with a 3/8" and it does not even flex without bracing. A properly braced 1/4" would do but only you can decide what that is since you are building it. Go with the 3/8" like bandaidmd said. CJ
This is what I'll do :)
   / SSQA Plate Thickness For FEL Plow #6
I went with 5/16, welded the push beam from an old Fisher Speedcast right to it. You'll fine fine with anything 1/4 and up, more than strong enough to hang the weight of the plow and withstand the pushing of snow.
   / SSQA Plate Thickness For FEL Plow #7
3/8" is pretty massive. Unless you are planning on a 9' or so plow, I would thin 5/16" is way sufficient. I used 3/8" and frankly it was too heavy for a 7'6" Meyers.
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
1998 FORD CRANE (A52472)
1998 FORD CRANE...
1990 JOHN DEERE 544E WHEEL LOADER (A52472)
1990 JOHN DEERE...
20304 (A51694)
20304 (A51694)
2020 Westfield MKX 100-83 Auger with Swing Hopper (A52748)
2020 Westfield MKX...
