SSQA lever and pin question
   / SSQA lever and pin question #1
bazman82
Lockport, NY
Same Mercury 75 Farmtrac 795DTC
Since this is my first ssqa I've dealt with, I am having an issue with the lever and pin not staying in the "up" position for when I need to hook up to something or unhook something. I am not sure if I just need to tighten up a nut or if I need to replace any of the parts of the mechanism. I assume it is something simple but I haven't taken the time yet to do anything about it because I haven't needed to put anything on the loader. Any ideas?
   / SSQA lever and pin question #2
the ssga on my tractor started getting loose and dropping so I adjusted the spring tension using the adjuster nuts. It was trial and error type of adjustment
   / SSQA lever and pin question #3
Mine got too tight, to where I was using a hammer to beat on the lever to open or close it. Not exactly ideal.
I examined how the lever works and made an adjustment to the nylon lock nut, now the cam over slides better. No more beating on it with a hammer.
I suspect that if you tighten that nut (or one similar), it will likely fix your problem.
   / SSQA lever and pin question #4
I just put up with it since the nuts on my (single-handle) SSQA are corroded enough to be non-adjustable any more. I've often wondered if it would be feasible to replace the lock-unlock lever with an electric actuator, so I wouldn't be getting on and off the tractor so much.
I fixed the issue. The 2 nuts just needed to be tightened half a turn each.
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
1996 International Water Truck with a Caterpillar Engine (A56435)
1996 International...
Deere 331G (A53317)
Deere 331G (A53317)
