SSQA lever and pin question
   / SSQA lever and pin question #1
bazman82
Lockport, NY
Same Mercury 75 Farmtrac 795DTC
Since this is my first ssqa I've dealt with, I am having an issue with the lever and pin not staying in the "up" position for when I need to hook up to something or unhook something. I am not sure if I just need to tighten up a nut or if I need to replace any of the parts of the mechanism. I assume it is something simple but I haven't taken the time yet to do anything about it because I haven't needed to put anything on the loader. Any ideas?
   / SSQA lever and pin question #2
the ssga on my tractor started getting loose and dropping so I adjusted the spring tension using the adjuster nuts. It was trial and error type of adjustment
   / SSQA lever and pin question #3
Mine got too tight, to where I was using a hammer to beat on the lever to open or close it. Not exactly ideal.
I examined how the lever works and made an adjustment to the nylon lock nut, now the cam over slides better. No more beating on it with a hammer.
I suspect that if you tighten that nut (or one similar), it will likely fix your problem.
   / SSQA lever and pin question #4
I just put up with it since the nuts on my (single-handle) SSQA are corroded enough to be non-adjustable any more. I've often wondered if it would be feasible to replace the lock-unlock lever with an electric actuator, so I wouldn't be getting on and off the tractor so much.
I fixed the issue. The 2 nuts just needed to be tightened half a turn each.
John Deere 2440 Tractor (A52384)
John Deere 2440...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
1261 (A50490)
1261 (A50490)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
