SS impossible connectors
/ SS impossible connectors #1
jmh1783
Darlington, PA
Mahindra 2555 HST
I put a 3rd function on my tractor recently and got a grapple. I knew the grapple I wanted came with skid steer quick connectors so I ordered the 3rd function kit with them. Now I'm regretting it. I got the grapple on, took it outsided and operated a few times then took it off as I needed the forks on for the next day. Fast forward a week, I was ready to use the grapple for real. When I went to put the hoses on I couldn't with all my strength get the SS connectors together. Tractor on or off. I even stood between the tractor and the grapple to get the best leverage.
I tried the trick of using a blunt object and hitting the center with a hammer. It didn't work. After some twenty minutes and a lot of huffing and puffing, I got a pair of wrenches and physically removed the connectors from the grapple side to let some pressure off. Looking at TBN I even saw a guy who turned a pipe clamp into a tool to crank the two halves together. Is this what I can expect from these connectors? Considering how expensive they are I would hope they would work better than that. I'm considering buying some industrial connectors like on the rest of my tractor and just tossing these. Any suggestions would be appreciated!
John
/ SS impossible connectors #2
You just need to relieve hydraulic pressure before you disconnect (cycle valves with engine off), that way next time you are not fighting high pressure fluid in the hoses of the grapple when you try to reconnect. You can still run into occasional minor situations even doing this, but it will eliminate the major cause of problems 99% of the time. This should be standard procedure when disconnecting any hydraulic implements with any sort of quick coupler.
Hi s219. The 3rd function is an electric solenoid valve. How do I relieve the pressure? Would not completely closing the jaws do that?
/ SS impossible connectors #4
I had a similar problem and solved it by cooling the hoses. Ran water over them.
Other times I made sure to disconnect warm, hook up cool, like in the early morning.
/ SS impossible connectors #5
If you shut the tractor down then turn your key back to the run position without starting the tractor, you should be able to cycle the valves with your third function switches. Make sure to open both valves several times and hold them open long enough for the pressure to bleed off. Give it a try, I think you will find it much easier to reconnect.
/ SS impossible connectors #7
You will STILL have an issue with the implement (grapple, tree grabber, etc.) if you take it off when it's cool and try to reattach it (or another implement) when it's hot out. The hydraulic fluid expands and pressurizes the QR fitting. It's nearly always the implement, as mentioned, you can drain the tractor hose pressure no issues. Sometimes you can attach the two implement connectors together as soon as you remove it; that will release pressure when you break the connection.
/ SS impossible connectors #8
:thumbsup:
/ SS impossible connectors #9
:thumbsup:
/ SS impossible connectors #10
On occasion I will have inadvertently disconnected my grapple hoses while they are still under pressure. If it happens, I just push the ball on the male fitting end, down onto the bucket until the fluid releases. It's pretty simple, but you may want to wrap a rag around it as you do it... The fluid sprays about 3' in radius.
I'll remember the trick about hot/cold. In this case, it was cold/cold since I only cycled the grapple to see if it worked then put it away. I'm still thinking of removing the SS connectors and replacing them with normal ones. The engagement even when the system was new seemed inordinately difficult.
/ SS impossible connectors #12
With the engine OFF but power to the valve solenoids, have someone hold the valve open while you connect the couplers. This always works for me on both of my machines, even when pre-relieving pressure does not. Since I almost never have anyone to help, I keep a small C-clamp handy to depress the buttons.
My theory is that the coupler has to displace a little fluid during the connection. if the hoses are completely full between the valve and coupler, there is no place for the fluid to go. Holding the valve open provides an escape route. They really connect easily that way.
Someday I may wire a switch up by the couplers to open the solenoid valves from there. No wife or c-clamp necessary then.
/ SS impossible connectors #13
Most times the tractor side isn't the problem. It's the attachment side. If properly disconnected, the problem is heat related.
/ SS impossible connectors #14
I hate Flat face SS couplers too.
So much so that I just swapped them out for 1/4" ISO 7241 B couplers. (parker 60 series....I run these on my snowplows too)
The whole idea behind the flush face couplers are that they are a low/no-spill design.
Without spilling those few drops of oil, they are indeed a bear to hook up.
As expensive as they are, if you still like the flat face couplers....they DO make a CONNECT UNDER PRESSURE version. You are supposed to be able to disconnect and reconnect under full rated pressure with ease. But they are even more money than the already expensive standard flat face couplers
/ SS impossible connectors #15
I use the standard 1/2 inch AG connectors but I do this when stopping and taking the grapple off. I shut off the tractor and then operate the valve back and forth several times to relieve pressure. If you have the electric/hydraulic valve then follow the above instructions about turning off the engine and turning the key back on to re-energize the solenoid.
I then disconnect the hoses from the tractor, and since I have both a male and a female connector on the hoses, I immediately connect the hoses to each other. I then immediately disconnect the hoses once again from each other. This allows a very small amount of oil to "puke" out of the hoses. Now the hoses have a deficit of oil in them. I then reconnect the hoses for storage. The male and female connectors help insure that dirt or damage does not occur to the fittings. It also insure you can never hook them up backwards. :)
Using this procedure, you will never never ever have a problem hooking back up to the tractor. No matter hot or cold or whatever. Remember, the key is allowing some oil to "puke" out of the hoses.
/ SS impossible connectors #16
I just received my current issue of Farm Show and it had this article in it on hydraulic connectors and a tool to relieve the pressure on them;
It looks like it may be hard to read here is a link to the tool;
Boling Machine
/ SS impossible connectors #17
Good tip James!!!!
/ SS impossible connectors #18
The times I have run into issues, has been when the lid for my grapple is in the up position and I have disconnected the lines. The weight of the lid will make it want to sag over time..putting pressure on the lines and causing it to be tough to re hook up. .. remembering to disconnect get it with the lid down eliminates the problem.
/ SS impossible connectors #19
I've had this issue for many years. I've tried all the remedies suggested in this thread with little or no result. For me, the problem is always with the implement connectors since the tractor side is easily depressurized using the methods previously described.
The first thing I did was dump the SS flat faced couplers and replace them with the Pioneer Ag style. I use female connectors on the tractors and the cheaper male on the implements. If necessary, the pressure can be relieved by tapping the ball in the connector end on a clean hard surface and releasing some oil.
For implements that are prone to pressure binding from cylinder creep, I use a simple manifold and keep the hose ends connected to it while in storage:
The simplest, cheapest but less glamorous way to prevent implement pressure binding is to use the open ended male Pioneer style Ag connectors without the ball check valve. When not in use, put the connector end in a heavy duty zip top sandwich bag and hold it in place with a rubber band. First, hold the bag open under the connector when breaking the connection to catch the leaking oil. When reconnecting, remove the bag, zip it closed with the leaked oil inside and toss it in the trash or burn barrel.
/ SS impossible connectors #20
If I plan to take one of my Grapples off, I open and close lid several times to get the hydraulic fluid really warmed up. Then I always close the lid. Shut off tractor, then key to on and cycle the 3rd function valve several times. Disconnect hoses in put end protector caps on. My grapples sit on a couple of stacked pallets under roof on shady side of my shop. My LS XR4155HC has 7241-B couplers.
When it’s time to hookup, I turn key to on, with engine off, and cycle 3rd function several times, then key off and connect hoses. I never have an issue hooking up again.
I use same procedure for my tree / post puller too.
My 96 HP New Holland TL100A and 84” HD grapple have flat face skid steer couplers, same procedure. I am considering changing to the 7241-B couplers so, I can use both grapples and tree/ post puller on either tractor.
Like others have noted, my 3rd function couplers are polarized so, grapples, etc. hookup same way every time. When I depress top of 3rd function toggle switch the lid opens. Press bottom side and lid closes. This makes Grapple operation very intuitive and almost muscle memory. When I hookup tree puller, depressing top side of toggle opens the jaws and bottom side closes jaws.
BTW, don’t waste your money on those pressure relieving tools. Take your $50 and buy cases of ice cold beer (or adult beverage of your choice) for relaxing after a successful day of grappling.
2011 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2011 Dodge Ram...
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2022 FREIGHTLINER...
ELLIOTT MAGNETEK 60KW DIESEL GENERATOR (A67714)
ELLIOTT MAGNETEK...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2009 KENWORTH T800 TRI-AXLE (A67714)
2009 KENWORTH T800...
