Squirrels in attic
/ Squirrels in attic #21
As far as getting rid of all the squirrels, I killed 10 in the yard one year. They were eating a strip up the south side of ears of corn in garden. They were gone a few weeks, then I thing 12 came back to replace them.
12 came to the funeral as pall bearers.:)
/ Squirrels in attic #22
I am pretty sure I sealed off were it was getting in, I used some old sheet metal I had lying around and screwed it over the hole it chewed to get in. I think I will get another live trap and put it out along with the rat traps. I need to get it out before it does any/anymore damage. Not sure if it has damaged anything yet or not, hope not.
When I sealed off the hole I was hoping it had already left for the day looking for food, but no such luck. I thought about taking off the sheet metal but didn't want him/her bringing any of his buddies in to party.
What did you seal it with? I've recently been told that the spray foam insulation works great, I haven't had a chance to try it yet. Steel wool works on smaller holes.
Hopefully you've gotten him locked out. They can be fun to watch, but not when they're in your house.
/ Squirrels in attic #23
I had a few causing me trouble last spring. Gray squirrels in my case. In the process of building, so I had not finished deck ceilings, and they got up in there and into the attached soffits. A couple connibears with peanuts did the trick. Got 3 within a few days and then the remainder cleared out as I put the ceilings up. I basically worked them into a corner, if there were were any remaining so that they would have to exit through a trap. They were all gone as I waited several days, then finished boarding it up. No problems since (crossing fingers)
This was the first 2 I got, pretty quick
Then I worked the ceiling down until I left only a couple openings for them to potentially get back out...and meet their maker, if there were any left. No action for a few days, so good to go, and nothing since.
/ Squirrels in attic #24
Traps work better when mounted vertically (dont ask me why) but they sure do. I cleared the property with a Whalter Blackhawk 177 cal. pellet pistol, get the red dot on them and game over.
/ Squirrels in attic #25
I second that! I had one shortly after I moved in here 21 years ago. The house stood empty for a year, except for the squirrels. One would sit at the corner of the house and chatter at me for hours at a time. 12 gauge loaded with rock salt in the face did the deed. 5 years ago we weeded out ALL of the tree rats that were hanging around here.....16 cats that hunt took care of them.(I rescue cats).
How did the shotgun barrel fair after that? My Grandpa did that once to a dog that kept getting in the trash. He says he will never do that again, and now shoots only lead.
I screwed a piece of tin over the hole. I have not found spray foam to be effective for mice, so I do not think it will work for squirrels. Although I did try the rodent repellent foam this fall for mice, I first plugged the hole with steel wool then foamed over it. So far so good with the mice. I was not aware they made a rodent foam until this fall, from my understanding of the product it is not poison, just taste bad. I am not going to take a bite just to check it out. :)
Problem with older homes, always doing remodeling and finding/creating (short term) entry points for the varmints.
Really like your ceiling. The wife has been after me for years for a covered deck. I just don't know how I would tie it in to the house as we have a metal roof.
Going to have to look at getting a couple of those traps, the do seem effective.
Well I ordered some conibear traps, a six pack of 110's one 220, a trap setter and a safety grip tool. Total cost $67.01. Estimated delivery date the 19th - the 24th.
I started a new thread asking how to take care of your traps.
I am now on a mission to eradicate the little furry tailed rodents from around my property. I have no problem co-existing with nature, it is when they threaten my property is when the war starts.
My mother in law used to feed the little critters until they found their way into their attic. Then the father in law went out and purchased a pellet gun. They lived in the city so the use of real firearms was not an option.
/ Squirrels in attic #29
Pellet guns in the 900-1200 Fps work just fine. Especially in 22cal.
Chipmunks are my problem digging down along basement for rain to run in. Those little guys are hard to hit sometimes
/ Squirrels in attic #30
A friend of mine swears by moth balls, it will keep mice and snakes away too. If you can handle the smell, LOL
We tried the moth ball thing when we had a double wide trailer on the lake. For us it did not work and the wife HATED the smell. Me on the other hand really didn't think it was that bad.
/ Squirrels in attic #32
An exterminator once told me that the only way moth balls will work is to use enough so that you can't stand it. However, I put moth balls in the little storage compartment on my ATVs and it stopped the mice from building nests in and on them.
I put one box under the trailer and the wife could not stand it. Didn't seem to bother the mice at all.
/ Squirrels in attic #35
IMO a strong pellet gun is too strong to shoot in buildings. A strong pellet gun could shoot through the insulation and sheet rock. I would much prefer a 22 LR loaded with rat shot. Any pellet gun capable of shooting over somewhere in the 1,100 FPS range will sonic crack which defeats the main point of a pellet gun.
Not shooting either in my house. Outside is another story.
He was in the process of procreating so I was able to get pretty close. I would have preferred to get the female (both really), but he had her covered up pretty good.
/ Squirrels in attic #38
Nope not at all. A trailer house is almost impossible to seal up from mice. It was a never ending battle. I had to have a regular trap line set up of mouse traps.
I'll have to remember that the next time wife starts nagging. Mothballs,,, brilliant!
/ Squirrels in attic #39
Why order them? Fleet Farm has them... Gotta be one near bemidji...
I wish there was a Fleet Farm near Bemidji, closet one is the Brainard/Baxtor area, a two hour drive. I checked L&M Fleet, but they did not carry them.
LeeBoy 8510C Leading Asphalt Paving (A61567)
LeeBoy 8510C...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2020 CAT 239D3 Compact Track Loader (A61166)
2020 CAT 239D3...
Yard Machine Riding Mower (A61166)
Yard Machine...
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
