squirrel in my celing
   / squirrel in my celing #1
jack707
up North wisconsin
farm trac 555
It chewed it way under my wood siding. Now the hole is fixed and thing is driving me nuts with all its chewing so how long can this animal live with out food because its been going on a year now.
   / squirrel in my celing #2
moth balls should drive them out if there is a way out...
   / squirrel in my celing #3
It sure hasn't lived up there a year without food and water. When my brother had a problem with squirrels in his motorhome, someone told him mothballs would drive them out, so he put lots of mothballs in there and the squirrels carried them all outside.
The only way to put mothballs there would be take up the floor upstairs over the living room.
   / squirrel in my celing #6
What makes you think it has no food? He's eating the insulation off your electrical wiring. Get ready for some expensive problems.
   / squirrel in my celing #7
No mammal can go more than a couple of days without water, and none can "eat" wiring insulation to stay alive. Rodents can strip insulation for other reasons for sure, but your problem is multiple access points. I fought with a couple of Douglas squirrels in our crawlspace for a year. They still got in after I wired shut every visible hole. The problem was water damage to my sill plate, allowing them to go anywhere along a long stretch and wrangle a new opening just above the foundation. In my case, they left little damage behind- just a midden pile and the access holes. They were mostly under there just to escape winter weather.
   / squirrel in my celing #8
Rat traps do a wonderful job on squirrels. It is a kill and release kind of thing. No smell left between floors. Peanut butter for bait. You must plug points of entry.
   / squirrel in my celing #9
Speaking of mothballs--My friend tried them to keep squirrels away from the bird feeder.
Blackbirds would pick up the mothballs and rub their feathers and when finished pass them on to other birds. Funniest thing we ever saw.
We only can assume that the birds discovered that the mothballs ridded them of lice or ticks, that or perhaps the females used them as perfume.
   / squirrel in my celing #10
Not sure what advice I have for that one...... I can say... if he chewed his way in he can chew his way out, they can also chew through PVC and even metal pipes which could get it needed water.... Many cold water pipes can sweat which can act as a water supply as well, if it has been storing nuts and food in there all summer and fall it could conceivably survive for a while. I get birds in the upstairs wood stove all spring and summer long, but they are contained and can't get out so I just catch them with a towel and put them back outside, I had to rescue three woodpeckers out of there this last summer.
You might consider unblocking the hole it was using to get in and out of, and put a trap outside the hole, get it out of the house and in a trap so it cant get back in, just a thought anyways, it would beat tearing your house up and if it didn't work you could still tear the house up later. Good luck.....
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
Gleaner R50 Combine (A50514)
Gleaner R50...
