squeaking noise in extreme cold?
   / squeaking noise in extreme cold? #1
azuerch
2021 Kioti NX4510
Hello,
I was clearing 8-10 inches off the drive yesterday with my Kioti NX and everything was running nicely. After about an hour out in the cold (approx 5 degrees) I would hear some loud squeaking type noises coming from either the steering column or maybe the front axle area? It was loud engough to be heard over the engine and through my hat and hood. It was only occasionally and seemed to be mostly when doing tight turns or turning steering wheel quickly. I was in 4wheel drive and engine temps were fully warmed up and normal. I'm guessing it was just the extreme cold temps affecting something. Is there anything additional I need to check maintenance-wise for cold weather operation? Tractor has 125 hours on it.
Aaron
   / squeaking noise in extreme cold? #2
The hydraulics definitely get affected by the cold. Mine are loud initially (3700 hours on the machine) when its bitterly cold but as they warm up they quiet down. Not much help to your situation
   / squeaking noise in extreme cold? #3
Sure its not in the steering column itself. Is there a greese fitting or lube point? Any joints in the column. I know when it gets real cold here i get some squeaks in the seat suspension. Spray lube solve it.
   / squeaking noise in extreme cold? #4
Normally I'd suspect a slipping power steering belt when that happens, but this should have the steering incorporated into the main hydraulic system. Could it be the bypass kicking in due to ice buildup limiting steering travel?
   / squeaking noise in extreme cold? #5
My "guess" is some plastic in the dash is touching the steering column or steering wheel ...
My steering column in enclosed in the dash so next time i'm doing maintenance i'll see if i can take a peak and maybe lubricate it.
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2004 CATERPILLAR 320C L EXCAVATOR (A60429)
2004 CATERPILLAR...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2000 Case 590 SL Backhoe Loader (A59814)
2000 Case 590 SL...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
