Square Baler for Hay?
   / Square Baler for Hay? #11
Re: Square Bailer for Hay?
The other important thing is to periodically remove the debris from the knotter area. If this builds up and then gets wet, it can cause mis-ties. Shut the unit down and blow it off with air or pull / brush it out with your hands.
We never did it since we baled most every day in a commercial operation, but keeping the knotters covered or inside should help prevent problems.
NEVER BE AROUND THE KNOTTERS WHEN IT IS RUNNING. That stuff moves way too fast to see anything and it can do bad things to you before you can react!
As a kid, we baled with Allis D17s (HP unknown) and JD 24 and 224 balers, both wire tie and nylon/twine. The tractors rocked with the plunger, but it handled the baler and haywagon easily.
At one time, I had a printout of how knotters worked. I'd run a baler for 5+ years and even after studying this manual, I never did understand how they worked!
Best wishes,
Ron
   / Square Baler for Hay? #12
Slowzuki:
With round bailers you don't have a flywheel and as the bale grows inside the bale chamber, internal friction against the bailer frame grows too. That's why most rounders have the option of fire supression (I have it on my NH). After running bales for hours, the bailer frame will be hot to the touch. The only exception to that which I know of is a Klauus, which rolls a soft centered bale. The Klauus uses rollers instead of belts.
The bigger the bale, the more horsepower it takes. When bailing wheat straw rounds with my 638, to get a maximum weight bale, I have to run the tractor at WOT to maintain 540 rpm.
On a different note, our "farm car" is a Suzuki. it is slow!! /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
   / Square Baler for Hay? #13
</font><font color="blue" class="small">( The other important thing is to periodically remove the debris from the knotter area. If this builds up and then gets wet, it can cause mis-ties. Shut the unit down and blow it off with air or pull / brush it out with your hands.
We never did it since we baled most every day in a commercial operation, but keeping the knotters covered or inside should help prevent problems.)</font>
I have seen ad's in farm magazines for "knotter blowers". They are basically an air nozzle that's directed at the cam where the bill hooks and cutters come together. I presume they have a small mechanical compressor that runs off the flywheel somehow. We never got into that. We clean the knotters when the bailer comes to the barn at the end of the day using compressed air.
As far as keeping the knotters "inside", I don't know how you'd do that. You couldn't put a cover on them, the needles would hit it. The best maintenance is keep it greased and chaff free as much as possible.
As far as "farm mechanics", around here, you call the respective dealer and the tech comes out and does his thing. JD techs won't work on NH and visa-versa.
   / Square Baler for Hay? #14
Sorry, didn't myself clear--what I meant was park it inside out of the weather or cover it up at night.
Sorry.
Ron
As usual, this is the place for finding out just about anything you'd want to learn! /forums/images/graemlins/smile.gif Thanks for everyone's comments.
My property is pretty much flat, so I'm safe on that end. I think that once I have livestock on the grounds that I'll only keep a five acre section for hay. As such, it really would be too small to get anyone to come by and bail, hence the thought of getting a square bailer. Besides, from what I've read the square bailes are prefered by horse owners anyway.
Curious, I see mention of a hay wagon to pull behind the bailer and the extra power required to pull it. At the risk of sounding dumb, what happens to the bail if I don't have a wagon? I'm assuming it just "pops" out on the ground. Thought of course is that I could come back afterwards and just toss them into the back of a truck or a trailer. I realize the "extra" work involved, but keep in mind it's only 5 acres.
Other thing I just noticed, the L3130 HST is a bit of a porker - weighs in at 3305 pounds. Looks like the 5030's only got an additional 440 or so (non-cab model at 3745 lbs.). Of course, by the time I put my large frame on the tractor the weight difference gets a lot smaller. /forums/images/graemlins/laugh.gif
   / Square Baler for Hay? #16
Yep that's what it does. /forums/images/graemlins/laugh.gif
Did some searching on the www for a JD 14T and found the following article on haying.
Haying FAQ
Loads of good info. Looks like they like the JD 14T too. Also found mention of mini round bailers used in Japan.
Agriquip
Interesting stuff, but rather pricey.
   / Square Baler for Hay? #18
My "real world" experience this year. I bought a 14T this summer. Once it was "tuned" by my J.D. dealer it has been pretty much trouble free. I baled my 15 acres this year. My neighbors found out I had a baler, now I have over 100 acres next year:).
I started out pulling it with my new J.D. 4010 = 18.5 PTO hp. This tractor is not heavy, but the baler worked fine behind it...provided I stayed where the ground is flat. Worked good going down hill too /forums/images/graemlins/grin.gif, glad I didn't have a wagon on though. It doesn't have the power to operate and pull the baler up the large hills I have so I ended up using my big tractor for it.
Keep in mind, the 14T is was not designed to produce bales as quickly as later models. If you make your windrows 1/2 as big as you think they should be, and then go real slow while baling, I think you will be real happy with it (and it keeps you on the tractor that much longer /forums/images/graemlins/grin.gif). This also keeps the tractor motion to a minimum. If you try to hurry it the big "F" factor will set in (frustration).
I'd suggest going to www.ytmag.com, click on Community Forums, then do a search for 14T. There is a ton of great information there also.
On a flat surface I think you could also pull a wagon behind it. NOT something you want to do with 18.5 hp though /forums/images/graemlins/wink.gif, or on hills due to the lack of weight /forums/images/graemlins/shocked.gif.
One other thing...and I can't stress this enough...buy a manual and read it through before you use the baler. Then read it again. Even though you won't understand part of it at the time, when you are up to your wrist in "knotter" you'll be amazing how quick you understand what you read. Oh yeah, and make friends with someone who knows how to work on these. The operation of the knotters is a lot like trying to understand women...kind of a lost art /forums/images/graemlins/grin.gif.
Good luck, and have fun.
   / Square Baler for Hay? #19
ICat:
That's what it does, pops out on the ground. Problem with that is that you have to pick them up and STACK them on a wagon anyway. Gravity is against you all the time and they get VERY heavy after about 50 or so. Its much better to have a chute extension on the bailer to the wagon so the bailer just pushes them to the wagon so you can stack them. Of course you could get a bale thrower like NH has and JD used to have. We have one on our JD and you can turn a bale into a guided missle if you want to. 5 acres X 3 cuts is quite a few bales. I hope you realize that there's a lot more to hay than just cutting. From you posts, I presume that you have an established field. Hay fields have a definite life span. After awhile the alfalfa and timothy will be crowded out by undesirable species. Horse people want good hay, not grass so to be marketable, there is quite a bit of maintenance involved. Fertilizing, pest control, overwintering, etc. Just ask Cowboydoc. If haying was easy, everybody would do it. Believe me, it's not.
To give you some idea...
You have to apply potash, usually at the rate of 200 pounds per acre in the fall for overwintering.
In the spring, apply nitrogen + a dash of Boron to promote growth.
First cut..
Mow, crimp, rake and bale. Hope your degree days are sufficient for drydown. After first cut, fertilize and watch for pests as the days are warming up.
Second cut..
Mow, crimp, rake and bale again. Keep checking for pests and fungus infiltration.
Third cut..
Same as second, but worrying about degree days and moisture.
Fourth cut..
If you are lucky, same as third, but...You must leave the hay plant high enough so that your winter kill rate is low. If you cut late and the plants are too short, the shock of cutting coupled with cold temperatures will winter kill your field.
That's just a short overview of how it works, or don't work. I don't know about CowboyDoc, but I don't contract bale on any fields other than my own. Yoy can destroy implements in a big hurry by hitting objects (logs, metal, old wells, etc) in fields that are not your own.
Again, there is alot more than just this. many varibles come into play. Besides, the bailer is just one small part of the whole picture. You must have a mower, a rake, crimper, tedder, bailer, wagons and slave labor. There is always the moisture problem. Bailed hay will rise in moisture content after bailing. We try to bale when the moisture is around 11% measured in the windrow. Bales will typically rise to about 15%. If the bales go above 18%, you will develop a mold problem and they will get hot. Horse people don't want moldy bales. I use electronics to measure moisture plus my own instincts. The instinct part is something that's acquired by experience. A good benchmark tool is a Delmhorst Moisture tester. We have probes to measure windrows as well as bailed hay. I also use a Farmex continuous moisture tester that has a sensor mounted in the bale chamber and senses moisture about 5 times every second. The readout is in the tractor and we have sensors mounted in the round as well as the square bailer. Moisture is the number one destroyer of good hay. Then you have to have a place to store the product out of the weather. If mother nature was perfect, it would be easy. She's NOT. That's why the price of hay is what it is. It's always a CRAP-SHOOT when haying.
I have seen those little round bailers and rakes in some farm rag. Looks like something a "wannabe" farmer might buy. Look pretty useless to me. Just a toy.
   / Square Baler for Hay? #20
Couldn't have said it better 5030. There is so much more to raising GOOD hay than people realize. You can go out and cut grass and such when you get a chance but making good hay is an art and alot of science. Since you brought it up it's not just wham bam let's put up some hay. People think you just cut if and bale it but most weekend farmers that I see making hay I wouldn't give two cents for it. If you want good protein content and forage preservation to lock in nutrients there is about a million times more thought and process than worrying if a compact will pull a baler. I think most people would be pretty surprised how worthless their hay is if they did a nutrient analysis on it.
2018 John Deere 640FD Draper Head (A53485)
2018 John Deere...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
