Square back Bushog?????
   / Square back Bushog????? #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
Got a lead on a used mower. It is a Bushog brand 5 foot mower. It looks a bit like the Rebel series but is built a bit heavier. It has been stored indoors and not used much even though it is at least 25 years old. I have never used a square back. What is the general opinion on them
   / Square back Bushog????? #2
Easier to back over trees to cut them off. Also they will dig in easier on turns.
   / Square back Bushog????? #3
I don't see how it will cUT in easier on turns? The back it higher than the front and the front has skids?
I wouldn't worry what shape it it. The blades on them all cut in a circle.
There probably rounded or angled off in the back to save on material or weight on most would be my guess?
   / Square back Bushog????? #4
The original SQ series of Bush Hogs are good machines. I had an SQ72 that I bought used and ran for about 10 years. Bought it for $400 and sold it this spring for $375.
   / Square back Bushog????? #5
I have a square back bush hog. It's a bit if a pain when your mowing along something like a building or a fence and want to turn away from it. Otherwise, it does the job.
   / Square back Bushog????? #6
The Bush hog "square back" models are actually 3 sided on the rear. The corners are cut off diagonally. Point being, the back of the deck is not rounded. An actual square deck won't cut clean outside corners because the blades are so far away from the rear corner of the deck.
   / Square back Bushog????? #7
Is that because there is less "lift" or suction developed by the blades, since the inside volume of the deck is much larger (than a rounded or angled deck)?
   / Square back Bushog????? #9
Nothing wrong with them. Square was the standard shape for many many years.
Round has advantages already mentioned. Better in tight areas and turning along a fence line, better suction, less weight hanging far back, etc. But they both work as intended
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Skidloader Bucket W/Hydraulic Attachment (A50774)
Skidloader Bucket...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
Walinga Agri-Vac (A50514)
Walinga Agri-Vac...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
