George the Beagle
BX 1860 occasionally sputters and dies. I changed both fuel filters last fall and still had problems over the winter. Hoping that I had water in the fuel, I change both filters again. When changing the one underneath the tractor, I figured I'd drain off a quart or so from the tank (after letting it sit 24 hours so the water would settle to the bottom). When I disconnected the filter, I took off the vise grips and....no fuel flow at all! I blew a little air back up through the line which then started a healthy flow of fuel. So, I'd say there is some crud in the tank. Which means.............uh oh........the tank has to come off?? I hope not. Unless, of course, someone has a better idea......!!!!!
