Sprocket style ring roller
/ Sprocket style ring roller #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I want put together a 6' to roller pulverizer to go over disced ground and haven't been able to find the smaller sprocket style rings 12-14 maybe 16 in od. I don't remember ID. Does anyone know of a supply for these? bjr
/ Sprocket style ring roller #2
Surplus Center has a good selection of sprockets and hubs in many sizes and pitches. There are several listed in the 10" to 15" range. Their latest catalog has 4 pages of them and another couple pages of pulleys, chains and accessories.
Not what I meant. I don't think we're talking about the same thing. A ring ring roller pulverizer is also called a packer or sometimes a cultipacker. These rings just look like a sprocket sort of. They are just big rings that are slid on a pipe axle (tube heavy wall) of smaller, say 2" smaller, outside diameter with some kind of flange or pillow block bearings on a frame. They just kinda roll and tumble to bust up clods for a seed bed. Pretty simple but effective. bjr
/ Sprocket style ring roller #4
Well, you learn something new every day.
Agri-Supply carries what you want, I think. Their buyers catalog has 16" and up. However they carry much more than what's in the catalog. You might try calling.
/ Sprocket style ring roller #5
Any idea where to get a 6 or 8 tooth sprocket that can be used for #55 manure spreader chain? I checked out the web sites for just about everybody, but no luck. Smallest was 12 tooth.
/ Sprocket style ring roller #6
Some places call them a floating ring pulverizer. I haven't found any individual parts either. I haven't seen them in the AgriSupply catalogs ... closest "looking" things I have found there are coulter wheels, which certainly won't work.
Attached are a couple pix for those that haven't seen them before. Most of the ones in my area use small rings, <12"
1997 JLG N40 Electric 40ft Articulating Boom Lift (A61567)
1997 JLG N40...
New/Unused Landhonor 100 Ton Capacity Hydraulic Shop Press (A61166)
New/Unused...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2021 Walker Neuson G25 20 KW Towable Generator (A61567)
2021 Walker Neuson...
2015 Chevrolet Express 2500 Passenger Van (A61568)
2015 Chevrolet...
832748 (A61166)
832748 (A61166)
