Sprocket and Chain -or- Pulley and Belt?
   / Sprocket and Chain -or- Pulley and Belt? #11
A generator has a pulse load: it depends on the change of magnetic field. I'm not sure if i use the right terminology, but it does pulsate.
A belt drive smoothens the pulse of the generator magnetic field changes, as well as the pulses from the piston firing of the engine.
Next to that, belts perform much better at high circumferential speed (1800 rpm)
The chain wont like that, its better suited for high torque, medium rpm applications.
We had a Claas mower with shaft drive and a slip clutch, PZ mowers were belt drive and didnt need a slip clutch.
   / Sprocket and Chain -or- Pulley and Belt? #12
Proud member of the Peanut Gallery
Just curious.. what makes you think you're in the PG? Because Egon said so? Because we had a discussion and differing opinions? Neither are automatic qualifiers...
I value our conversations.. difference of opinions or not..
Soundguy
2020 DRAGON ESP...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
LOT: (36) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #2 Grease (A59076)
LOT: (36) 14 Oz...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
