Springs to make hose holder/guide
   / Springs to make hose holder/guide #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Looking for a source of springs to make a hose holder/support to keep hoses from dragging and scrapping in different applications. EA makes or used to make a kit, but it was pretty pricey for what it was.
   / Springs to make hose holder/guide #2
Look at NAPA or other trucker supply stores for holders that hold up the air lines extra behind the cab of the truck. Old CB antenna might work.
   / Springs to make hose holder/guide #3
Go to a farm store and see what you can find.
   / Springs to make hose holder/guide #4
I realize this will not work for you if you don't have a supply of the right wire and a lathe but when I need something like a spring, I go to my supply of galvanized telephone wire that my Dad salvaged back in the day when the local exchange was burying the cables to get around the constant storm damage. I use a wooden dowel slightly smaller than the diameter I need and with the lathe speed set at a slow turn, wind the wire around the dowel till I have what I need. I've never made one for the purpose you describe but I just might now because I could put that to good use around my machinery!
Pull-Behind Ripper Attachment (A49461)
Pull-Behind Ripper...
2000 Ford F-650 TMA Flatbed Truck (A49461)
2000 Ford F-650...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
