Spring Mowing Late this Year
   / Spring Mowing Late this Year #1
TerryR
Veteran Member
Boone, NC
JD 870
I'm a little late with the spring mowing of our field this year, and it's offering my John Deere 870 all it wants in third gear (2½ mph):
The flail is doing a good job on it. But I'm going to have to get a couple more cans of diesel, as it's going though it faster than usual.
   / Spring Mowing Late this Year #2
I'll bet it less diesel than if you were pulling a rotary cutter...
   / Spring Mowing Late this Year #3
That flail is giving a very clean cut (y)
Think of the fuel as being less than 2 cuts you may have done had you gotten on it early. I have a lower field that grows like crazy, been cut 4 times since January... and the mustard is 2 ft tall again.
Actually, I found the flail normally requires at least half again as much fuel as my old rotary.
It does this time of year. Not so much in the fall when some of those weeds get stiff and the flail wants to bend them over and not cut them. But it does a lot better even then since I replaced the factory belt guard with a chain guard.
   / Spring Mowing Late this Year #6
I have the hammers on mine and it rarely cuts as clean as you showed, do you have finnish cut knives on yours?
   / Spring Mowing Late this Year #7
Have you ever thought about spraying it with a little herbicide to kill the wild mustard?
   / Spring Mowing Late this Year #9
2,4,D will kill wild mustard and will not harm grass, as always read the label, but it should get it done for you.
AC CHARGING MACHINE (A50854)
AC CHARGING...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
Unused 2025 CFG MH12RX Mini Excavator (A49461)
Unused 2025 CFG...
2019 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2019 Ford F-550 XL...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
