Spring loaded stand-off for plow hydraulic lines
   / Spring loaded stand-off for plow hydraulic lines #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
The hydraulic lines for my snowplow kinda hang near pinch points when I'm snowplowing. I noticed my MX-8 rotary mower has a nice thick spring wire with a loop on it to hold the hydraulic lines up in the air to keep them from getting damaged. Would like to put similar stand off on my snowplow.
I would order the part off my MX-8, but it mounts differently with a locator pin.
Bottom line is, does anyone know of a hydraulic line support that mounts to a flat surface? The mount must be bent 90* at the bottom to accept the mounting bolt.
   / Spring loaded stand-off for plow hydraulic lines #2
Pretty easy to make if you have a welder. I've just used 3/8" hot rolled round stock and bent it to the desired shape and welded it the implement. If its long enough, its somewhat flexable. If you prefer to bolt it on, you can weld it to flat strap with a bolt hole. If you want the spring mount, maybe make it out of a hay rake tooth. Don't know where you would buy one ready made.
Kim
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
3pt Ditcher (A50121)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
