Spring house rebuild
/ Spring house rebuild #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
The spring house was crushed from tornado tree damage this summer. The spring was the water source and refrigerator for the 1000acre land grant over 250 years ago. It was rebuilt ~80 years ago with mostly white oak, rock and concrete. Currently supplies water to three houses and farm. Have done some maintenance and and roof replacement over the years. Treated lumber, plywood or store bought lumber just doesn’t last in this environment. The spring runs thru the building.
Trying galvanized steel framing and oak and walnut 1” rough sawn siding attached with reamer screws.
Still a work in progress. Hopefully will last as long as the last one for generations to come.
/ Spring house rebuild #2
We use a small spring on our place for our water source. I built a shed over it sorta like yours back in the 80's, and it lasted about 30 years. Now at the collection point, I built a block box about 40" square with a sheet metal lid on top. Water collects in the box, runs in a 1" pipe down hill about 50 yds to a point I could build a building to house two 1500 gal poly tanks for storage. The spring fills them constantly, the excess run out a fitting near the tank top. and into a 1" line along with the supply line on down to the house and rest of the place. The overflow line I plumbed into a fish pond to give it near constant water supply, along with a tap on down to the chickens and cows so they have a constant supply of water....they get it first, then the fish pond. Second fish pond receives the overflow of the first one.
Whole thing is gravity feed so no pump required, but I do have a booster pump at the house to take the incoming 25psi and boost it to 40-60. Also have a UV sterilizer light set up along with filters to make sure we don't get a dose of something out of the spring.
Tank storage building 10'x20':
enhance
/ Spring house rebuild #3
I like the idea of using galvanized posts, but I question how long oak and walnut will last? In my experience, if you want it to last, you have to use materials that cannot decay. PVC, plastic, Cement, rock, brick and metal.
The cabin in the background was the original homestead. Even paper thin loss of wood per year over centuries adds up. Thinking wood siding would be aesthetically pleasing in the setting. If a tornado thrown tree hadn’t crushed the last one it would be have maybe lasted another 80 years.
On the spring house no wood will now be in contact with the ground or stone. 2” thick by 5’ white oak planks set in stone to walk over the spring I replaced over 45 years ago still can hold my ample weight. They too will be replaced by aluminum bar safety grating as part of the rebuild.
The couple I bought the farm from, she did all the building and farming. Restored the cabin, spring house, built a 4500sqft castle out of rock and repurposed materials. Building solar back in the 1940s. Both Manhattan Project pioneers. Remarkable folks.
We daily pump water on a timer up to a cistern 1/2 mile up to the said rock house. Back pressure supplies water to the farm and cabins at ~100psi. 14 stage deep well pump lays in the spring.
I see I messed up and didn’t post this pic with the original topic.
Finished building. Done a little grade work after photos.
Be interesting how well the galvanized steel framing will last the environment.
/ Spring house rebuild #7
Looks great!
Where did you source your galvanized steel framing products/materials?
/ Spring house rebuild #9
Thanks for the pictures. That came our really nice!!!
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
