JJT
Veteran Member
- Joined
- Oct 13, 2001
- Messages
- 1,812
- Location
- Upstate NY, USA
- Tractor
- Kubota L3710 HST and a Kubota ZD21 60Pro
Heads up, Jim MacFadden's spring auction is just around the corner. I've attended quite a few of Jim's auctions, and think the ones at his site are the best. Just do me one favor - don't bid against me!
Saturday, March 30, 2002, 9:00 am
100+ Farm & Compact Tractors, 100+ Implements, 50+ Antique Tractors & More!
At our yard on US Route 20, 4 miles East of Sharon Springs, NY
This is an early listing made March 5, 2002, much more coming daily!
FARM TRACTORS: Case IH 5220 w/ldr; JD 4050 MFWD powershift-nice!; JD 4640, 4440, 4240, all HFWD, cab & powershift, JD 4630 powershift, cab; JD 4955 MFWD, duals, open rops; JD 2950; JD 4020; JD 4520 w/cab & duals; JD 4320 4WD; JD 2850 4WD & Cab; Field Queen forage harvester w/ dump box & 3 heads reconditioned & field ready; White 2-135 MFWD; White 2-155 w/duals & 540; White 4-175 4WD; White 2-105 w/cab; (2) AC 185S; IH 6388 2+2, 4500 hrs, very good; IH 3588 2+2, 3200 hrs, sharp!; 1H 656; Case IH 3220 1800hrs; Landini 10005 4WD w/cab, 95hp; IH 1086 w/cab, wgts, 4500 hrs-sharp!; IH 1486 w/cab, wgts, 3 hyd, 4300 hrs, nice!; IH H, M, Cub; AC WD, D17; Ford 8N, 9N, 800; Many more farm tractors of all kinds coming in.
COMPACT & LOADER TRACTORS: Ford 1620 hydro 4WD & Idr; Cub Cadet 7194 4WD & ldr, 320 hrs; Case IH 255 4WD & Idr; Ford 5610 4WD & ldr; Ford 1710 w/ldr; Kubota 4950 4WD & ldr; JD 2350 w/ldr; (2) Nice JD 1140's; Sharp Ford 3000; Ford 2000; Belarus 250; (2) IH 504; IH 460 w/ldr; Lots of smaller tractors coming in! ! ! ! !
INDUSTRIAL: '92 JD 4006 dozer, 1700 orig hrs; Cat I T 12 wheel ldr; Case 580 K extendahoe, 3515 hrs; Ford 4500 TLB, super clean original; Ford 4500 TLB w/cab; Cat D4D dozer; Bobcat 853 w/cab & 2200 hrs; Case 1835B dsl; (3) apt hitch backhoes; York rakes; post hole diggers; 20ft Jeff Dann rollback body; good IH DT 466 truck engine; many more items coming in!
ANTIQUES: Ultra-Rare Massey Harris 1244 G Air Force tractor; '28 Cat 20 low seat orchard crawler; Very nice original IH Super MV Hi-Crop s/n F27883J; Nice Oliver OC6 dsl crawler, new tracks; JD 730 dsl, ES, apt, fenders, restored; IH W4, W6, W9, all perfect tin; restored '66 Ford 1 ton truck; rare Oliver 1800 wheatland LP gas w/apt 1 owner; Rare LeRoi Centaur w/factory apt; Very good '53 Cat D2 w/angle blade & winch; Nice original late JDB w/water pump; JD slant dash A&B; JD H; JD Styled D; JD 430 U w/ps; MH 55, 44 std; MH 44 dsl; MH 33, 22; Several JD A's; JD B w/single front; Nice original Coop E-3; IH 400 dsl; IH 22-36; Nice original Farmall H w/M&W 9 speed & live hyd; Nice MM M-5 dsl; MF 130 vineyard; Early Economy w/implements; MM 670 LP; 111 W-400; Sharp Case 930 gas; 1H WD9; IH 560 Wheatland dsl, nice original; IH 660 dsl; JD 420 U; (2) JD 60; JD50; Nice Case LA; JD R dsl; Very nice original Case S; Oliver 88 dsl; Nice Oliver 880; AC CA; (5) pull-type plows; Wagon load of parts & 20-30 more old tractors by auction day!
FARM EQUIPMENT: Brillion 25' cultimulcher-like new; Krause 4900 21' rock flex disc- absolutely like new!!; Durham 12' cultimulcher; Brillion 12' cultimulcher; Brillion 10' cultimulcher ; Krause 20' & 28' rock flex discs; JD 220 21' disc; Wil-Rich 8X flex frame reset plows; 1H 475 14' heavy duty disc; Miller 15' offset disc; 1H 720 4X18 reset plows; IH 720 5X18 reset plows; 1H 735 6X veri-width reset; White 588 5X18 reset; White 3X spring reset; Many smaller plows apt & pull type; Several 10' discs; White 5100 4R planter; JD 7000 6RN dry fert-nice!; IH 56 6R planter; Nice Buffalo 6R ridge til planter w/Kinze units; Buffalo 6R cultivator both like new; Generac 60 KW alternator; Gehl 1475 round baler; JD 330 round baler; IH 3pt backhoe w/3 buckets; Kelley apt backhoe; Davis apt backhoe; Leon 690 ldr to fit CIH 5120, like new; New Demco 12 ton HD running gear; 5 shank V ripper; MC 12' HD flail mower; Woods 315 15' batwing mower; Nice Woods ditch bank mower; Lots of used bush hogs, loaders, duals; 50 new tires; various new & used apt equipt; 100 pallets misc parts; plus many more items of all shapes & sizes coming in daily!
