Spreader Spreaders "walk behind" vs 3 point hitch
   / Spreaders "walk behind" vs 3 point hitch #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
Spreaders \"walk behind\" vs 3 point hitch
Since its never too early to start your Christmas list:
I want a spreader for fertilizing, lime (probably pellets) and grass seed. My lawn is littel under 2 acres. I've used a commercial grade walk behind spreader before with good results.
Suspend your tractor bias for a minute, Any reason I should choose a 3point hitch version over the walk behind?
I know the walk behind is "lower impact" if I were to be seeding a new lawn.
I actually have a POS scotts that I bought for $20 to do my lawn renovation last weekend. It doesn't even hold a full bag of fert or lime!!! But I needed something Sunday morning & that's what was available. So I'll have that to use if necessary.
I like the idea of riding vs, walking, but am I giving up too much in manueverability?
   / Spreaders "walk behind" vs 3 point hitch #2
Re: Spreaders \"walk behind\" vs 3 point hitch
I'm kinda considering one to that mounts on my ATV or on a 2" receiver, usually under $200. I just used about 300 lbs of lime/fertilizer and wheat on the ole garden and my push spreader that holds over 50lbs wore my butt out.
I used my ATV and an empty pallet to drag the surface and cover the seed. Lookin' for a little rain to see how it works.
   / Spreaders "walk behind" vs 3 point hitch #3
2 acres is not THAT much, but the 3-point allows you to spread it quick, and without refilling. When I use my spreader I spread a 40 foot swath, and go at maximum speed in medium range - probably 5 or 6 mph. It is really fast.
   / Spreaders "walk behind" vs 3 point hitch #4
I got a 3pt spreader ealier this year. I now can spread 500 pounds of fertilizer on my 4 acres of lawn in about 30 minutes. A walk behind spreader would take me half the day and wear me out.
I also have been buying Ag fertilizer from Agway this year for the lawn. I just put down some 20-7-13 (12.5% ammonium nitrate) last week and the lawn is loving it.
500 lbs. is about $50 which is much cheaper than buying anything at HD or Lowes. It doesn't have slow release nitrogen so I was worried about burning the lawn at first but I haven't had any trouble at all.
Kevin,
Small world, I broke my thumb skiing at Song Mountain! Had to have it fused together as I did too much damage to the joint.
So three point sounds faster, Are you guys using them in open fields or do you have to drive around some obstacles?
   / Spreaders "walk behind" vs 3 point hitch #6
I've got the three common types.. the junk walk behinds.. carry about 20#.. I god a slightly nicer 100# unit that pulls behind a lawnmower or atv... will also areate with tines, etc..
Really don't like it.. and it was almost as much as the small 3pt one I got at tsc. The one from tsc was less than 3oo bucks.. has a flexible 'universal' pto coupler.. and holds about 2-300 pounds of seed / fertalizer.
I did my 10 and 3 acre pasture with it fast... like someone else said.. you can get a good swath at dectnt ground speed going. I got about 30' of great coverage.
Soundguy
   / Spreaders "walk behind" vs 3 point hitch #7
haz,You can buy commercial walk behind spreaders of good quality and performance.Or you can buy a 3-point type,I prefer the tractor mount,simply because it's another reason to climb on and "work".
We own the smaller "hopper type" spreader that Landpride offers,350 lbs. capacity,I hook this up to our BX and it works great.This style spreader, of about any color are all made by a Company in Italy,I can't come up with the name.
If you opt for this type spreader,one thing you want to watch out for;these things spread a LOT of material in a hurry.On granular fertilizer,I have the gates set at about 1/2".When spreading Ag Lime (non-pelitized) I will open the gates all the way.I also buy fert. in the bulk,MUCH CHEAPER,plus you can have whatever formula you want blended.
   / Spreaders "walk behind" vs 3 point hitch #8
Re: Spreaders
Hazmat, I can see Song Mt. out the window. It's small but close, we ski there every weekend in the winter. I jammed my thumb into the snow a couple of years ago but at least it was in Austria so I could make up a good story to go along with it.
My property is pretty much wide open but I don't have any trouble running around the obstacles that I do have. I spread a swath about 30-40 feet wide and set the gate opening small enough that I need to go back and forth in one direction and then perpendicular to that with the rest. I haven't had any trouble with streaking or burning anywhere.
The one I got is made by Sitrex. <A target="_blank" HREF=http://www.sitrex.com>http://www.sitrex.com</A> I think these are sold under many different brand names.
   / Spreaders "walk behind" vs 3 point hitch #9
Re: Spreaders
They don't have a dealer listing ....
   / Spreaders "walk behind" vs 3 point hitch #10
MReeter,
What type of spreader are you using that spreads ag. lime? I want to get one that will do that. I use ag lime that has the consistancy of fine sand, not powder, and is stored outside in a pile and is damp but not completely wet unless it has been raining. I looked at one brand that makes a nice heavy duty spreader made for sand and salt spreading but it was $1200.00.ouch!Marty
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2021 Bell B30E Off Road Dump Truck (A53117)
2021 Bell B30E Off...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
