blueriver
Super Member
- Joined
- Oct 4, 2007
- Messages
- 5,012
- Location
- S.E.Oklahoma
- Tractor
- JD 5520 Montana 4340 Farmall Super A Montana 5720C
I am a novice farmer and need some advice on Spraying Equipment.
I need to buy a spray rig for my 40 acre hay field.
How much water does it take to spray an acre of ground, in general terms?
I realize that different chemicals take different strengths and I will have to adjust for that.
Would a 150 gal tank be sufficent, or do I need something larger.
I am looking for a 3 point mount on the back of my 585 Case IH tractor.
Its really not as complicated as some would like you to think. If you can read the manual for the sprayer you can calibrate the sprayer ... if you can read the directions on the chemical you can mix it...you can calculate ground speed for the tractor.
Use eye protection and rubber gloves while mixing ... spray in the early mornings with no wind and you can do it!!
Buy 150 gallon 3 point sprayer ... I prefer boomless nozzles.
In reference to the custom spraying, they all vary depending upon acreage covered and what your spraying.
