Spraying herbicide??? Tell me how
/ Spraying herbicide??? Tell me how #1
HCJtractor
Veteran Member
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I plant about 20 food plots every fall, rarely in the spring. Although I have a little clover left alive, the grasses are really taking over this year from so much rain. I bush hogged and started to plow, but the tough grass really clogs up my plow. I believe that I could get a better food plot if I kill all these grasses. Do you guys do this? My food plots are usually long and narrow or oval. Total acreage of them all is about 10 acres.
Questions:
Does it help? When do you apply?
Will the grasses reseed themselves and be just as bad each year or is there a residual effect?
What kind of sprayer? 3 point hitch, trailer style, or 4 wheeler? Advantages of each? i am kinda leaning to the 4 wheeler style. A trailer style would have to be able to withstand some rough washed out roads. But a three point can be larger, but do I need a big volume? What specific sprayer and at what costs?
Boom or boomless? How tough are the booms?
How many gallons per acre and what chemical?
Somebody please walk me through what you have success doing. Thanks!!
/ Spraying herbicide??? Tell me how #2
Go the Iowa Deer Quality Management site (google it) and you will find everything you need to know about food plots and weed control. There is a great thread by a guy who goes by Dbltree. It's called "Dbltree's Corner"
Dbltree's corner - Iowawhitetail forums
/ Spraying herbicide??? Tell me how #3
I have a 15 gallon atv sprayer that I bought about 10 years ago. It was designed as a spot sprayer with a want but I wanted a boom for the same reason as you. Last year I decided to make my own boom because I didn't like any of the commercial ones for sale (too flimsy) and they were too expensive. I ended up making one with five nozzles spaced 20" apart. The boom itself is a piece of 1" square steel tubing and it's seven feet wide. Given the spray pattern it'll actually spray a nine foot path, but the boom itself is 7'. You can buy all the parts at tractor supply company, that's where I got mine. The salesmen there can help you with all the stuff you need, I walked out of there with a bag full of parts and all total it cost me about $70 to build the boom, but it's better than any commercial one costing $150 or more. I mount it to the bottom of my rear ATV rack using zip ties, then just cut them when it's time to take it off. It works REALLY well and I use it all the time. I've never hit anything with the boom I built but it's pretty solid, I doubt I'd hurt anything if I did and the zip ties would just tear off. You can get the boomless kinds but I believe the boom does a much better job.
By far the most popular herbicide for purposes like yours is Roundup, it does a real good job of killing grasses. They make it in generic and that's the way to go, it's much cheaper than the branded roundup. Your local farm supply should have it but I've found it's cheaper to buy it off the internet. The generic name is glyphosate. Here's where I get mine:
Drexel Imitator Plus Glyphosate 2.5 Gallon Jug w/ 15% Surfactant America's Farm & Home Store
I usually buy 5 gallons at a time, it's cheaper that way and with shipping it's about $90 for five gallons of the 41% concentrate. 5 gallons will spray about 20 acres at the rate I mix it.
For grasses I use a quart of 41% roundup per acre. In my sprayer I'll go through about 15 gallons of mix per acre so I mix one quart into 15 gallons of water. It works out to roughly 2 oz. per gallon. I measured how quickly my sprayer flowed and did all the math until I figured out that I can spray an acre in 12 minutes if I go 5 mph on the four wheeler. 12 minutes is how long it takes my sprayer to empty if the 15 gallon tank is full.
It does help a lot with the disking, especially if it's a field that hasn't been worked before. The roundup kills the roots along with the grass. The roots are what holds the soil together and makes it so hard to till. The grass will come back the next year but the roots won't be as deep as the first time so it'll be easier to till. You need to spray the grass at least two weeks before you get ready to plow/disk in order to give it time to die and the roots to degrade a bit, and 3-4 weeks would be even better. I'm going to plant food plots at the end of september and I'll spray in the next few days, whenever it quits raining. I won't spray all my food plots, the ones that have I've been planting for years I'll just bush hog and disk, they'll break right up. I've got a couple of plots that are new and they've got a lot of tough grass on them so I'll spray them.
/ Spraying herbicide??? Tell me how #4
Get a boom. I believe fimco make a 25 gallon atv sprayer with a 7 nozzle 10' folding boom kit. Much better cover than boomless nozzles, and it is spring loaded wings to fold back and not break it you hit a tree or post.
Chemicals?
To kill only grass use clethodim(arrow,select) mixed with 1% crop oil. One gallon jug will do ~15 acre of clover at 8oz/acre.
To kill everything use generic glyphosate. It will take around a month for it to "burn down"" good enough to make your tillage easier. I'd go with a higher rate, around 3 qt/acre to get a more effective kill of mature weeds, and that stuff is cheap. You want your sprayer set up(calibrated) to put out at least 20 gallons of water per acre, you can get by with 15, but I like 25 better. That ensure even coverage.
/ Spraying herbicide??? Tell me how #5
I just started with the clethodim this year; its a good way to resurrect clover plots.
/ Spraying herbicide??? Tell me how #6
Yes, absolutely kill the grasses (and weeds) with herbicide. I like Roundup, or one of the imitation glyphosate brands. There's several out there so shop around. I have a 25 gallon tow-behind sprayer with a boom that covers about 8 to 10 feet, but I'm only doing a couple of relatives small 1/2-acre plots. ... and the trailer bounces quite a bit on the uneven ground. For your size parcels - totalling 10 acres) I think you'd want something a bit more substantial, like a 50 or 100 gallon sprayer that mounts to the 3-pt. ... just my two cents, but otherwise I think you'll be frequently stopping and refiilling/remixing. Seems like TSC and Northern Tool have a good selection, but I'll bet there's many more out there.
..By the way, consider a marking additive, like Hi-Light or Blazer blue die. You'll be able to easily see where you have and have not already hit. I like Hi-Light because it washes of your hands, clothes, spray equipment relatively easily.mitate
/ Spraying herbicide??? Tell me how #7
Use Glyphosate get the 41% kind and get it from a landscape supply or TSC you should be able to get 2.5 gallon jugs for under $50, if you buy round up in this quantity (lowes has it) it will be well over $150. This stuff will kill about anything at 4oz/gallon.
Spray with a 4 ft boom sprayer on your 4 wheeler or tailgate of your truck or rig up a carryall on your tractor for it. Spray in the fall for best work. Id spray now and give it 2-3 weeks for good kill then disk it. You will have weeds next year from the seed this year but if you spray again next year your field will be pretty clean the next years where only inported seed will sprout and old seed in the soil. By imported i mean by your tractor implements birds and wind.
/ Spraying herbicide??? Tell me how #8
I got a real good deal on Poast + at a local farm store. It was $125 for 2.5 gallons. It is very similar to Arrow/Select. It will only kill grass.
Another one for grass only is Fusilade. Believe it is a lot more expensive.
/ Spraying herbicide??? Tell me how #9
True, but I've had better luck with 8 oz arrow than 32 oz poast plus.
Clethodim $4-$6/acre
Sethoxdim $8-$12/acre
Some 4-wheeler sprayers are "boomless" yet put out a wide swath. Others have foldable booms. I have been told that the foldable booms may give more accurate even coverage but for food plots, the boomless style is "good enough." From what I can see, Tractor Supply only sells the boomless style. Any thoughts on which is better overall?
We also spend a lot of time on the edges of roads and plots that keep closing in every year. Does anyone spray laterally to minimize this? Just wondered. Thanks for all the info. Keep it coming!!
/ Spraying herbicide??? Tell me how #11
Boomless nozzle are good enough for glyphosate if you make double passes. For anything I wanted to kill growing in something that I did NOT want to kill(ie: grass in clover) I'd use a boom.
Most boomless nozzles do not throw that high, but you can use a spray wand from the seat of the tractor for road widening with something like crossbow.
/ Spraying herbicide??? Tell me how #12
If this is a problem i would. I'd take a wand type sprayer either on your 4 wheeler sprayer or backpack or even the 2 gallon pump type and spray all down the sides of the woods into the edge to get all the grasses and sweetgums and pines the "creep" in. For this i would use Glyphosate (roundup) as it will not kill anything that you contact only the woody stem, like the bark of a tree. So if you hunting a pine plantation you can spray the edge kill grass and small sapling pine but not kill the crop trees. If in Hardwood you wont kill them unless you get it on the leaves, this is true even for a tree as small a 1'' diameter, it wont kill it unless you get the leaves. You have to hit "green" material, weather it be a green stem like in grasses or the leaves.
But my point is you can trim branches on large trees (only do this if you dont care if the tree dies , it may) kill grass and small trees that you can spray overtop of to help keep them from creeping into the plot area.
Where in UPstate are you? I live in Greenwood co, and have afarm in Lancaster Co.
-Nate
/ Spraying herbicide??? Tell me how #13
The round-up and generics will kill everything. You may not need to do that. I've been using "sethoxydim" by brand name of Poast or Poast Plus with crop oil. (I will check out the clethodim if it's cheaper and as effective).
From experience, the sethoxydim works best early spring when the ground is still almost too wet. Grasses in the 1-2" height. Around here, the best time to spray will rut the fields up real bad and probably stick the tractor. But, it does work later in spring when the fields are dry, but you have to mow a week in advance then spray. Takes 4 weeks to kill, but you can see the missed areas as green swaths in red after 2 weeks.
I was able to spray my home plots this year, but not my remote ones due to 2 1/2 " of rain a week since June. Everything is still soggy in the mostly low remote acreage. The home plots have a few grasses sticking up, but the remote areas are mostly grass with some clover under it. A crying shame with the cost to plant.:(
I use a 3pt 30 gal sprayer. It's really too small for anything over 1 acre. But it's what I could afford....
/ Spraying herbicide??? Tell me how #14
I think I saw you are in SC. I ordered a Fimco brand through AgriSupply as it was cheaper even with shipping than buying it locally. I talked to the people at Fimco prior to buying and given my primary application is broad leaf weed control and I wasn't looking for precision, he suggested the boomless. I wanted to not have to worry about hitting the booms on trees and the boomless allows me to go down a fence line or edge of the woods. I added a wand and it is pretty effective for getting the ditches. There are different pumps for round-up type products, so watch that when buying.
55 GALLON 3 PT SPRAYER - Agri Supply
207278 (A52708)
207278 (A52708)
John Deere 1025R (A53317)
John Deere 1025R...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2003 Big Tex 10PI...
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A59230)
2015 International...
