Sprayer sprayers 101
/ sprayers 101 #1
CTyler
Blair, Ne.
L3130
I'm looking to get a 3pt sprayer for my L3130. What if any is the disadvantage of using a boomless sprayer?
I'm looking at one from TSC 60 gallon with three nozzels and runs from my PTO pump. The nozzles can be turned off individualy at the nozzle.
Needs are spraying fert for the lawn aprox 1 acre. There are also three areas of grass along the tree line and up the drive. Each one is 600' plus and 12-14' wide.
Also want to spray the nettles along the whole tree line, aprox 1700'.
/ sprayers 101 #2
The biggest disadvantage I have experienced is control. The boomless sprayer has more tendency to create drift. The fine particles blow easier in the wind. Fertilzer and weed spray burn trees and could cause you problems. I would look at the 12 foot boom for your sprayer, you can still control each section of the boom and it works quite well.
/ sprayers 101 #3
</font><font color="blue" class="small">( The biggest disadvantage I have experienced is control. The boomless sprayer has more tendency to create drift. The fine particles blow easier in the wind. Fertilzer and weed spray burn trees and could cause you problems. I would look at the 12 foot boom for your sprayer, you can still control each section of the boom and it works quite well. )</font>
That sums up boomless sprayers quite well. If ALL you were spraying was fertilizer, I'd be OK with one. But when you spray pesticides, you need all the control possible. Small nozzles, low pressure, and NO WIND are very important.
/ sprayers 101
The boom type they have at TSC is all or nothing, can't turn off sections of it and has a single on/off valve.
A boomless would to be able to spray one side only 10'+ into the trees. Either that or a boom type and a spray gun/wand.
I'm assuming the spray guns have an adjustable spray pattern? Haven't looked into them, anything specific to look for? Last year I used a 1 gallon hand sprayer and that was almost a joke. Had to fill it up a bunch of times and took quite a while.
/ sprayers 101 #6
</font><font color="blue" class="small">( The boom type they have at TSC is all or nothing, can't turn off sections of it and has a single on/off valve.
I'm assuming the spray guns have an adjustable spray pattern? Haven't looked into them, anything specific to look for? Last year I used a 1 gallon hand sprayer and that was almost a joke. Had to fill it up a bunch of times and took quite a while. )</font>
I guess that the entire issue has more to do with the INTENDED USE of the sprayer than anything else. I use my sprayer to put down weed control chemicals on pastures/hayfields/crop land/fencerows. I use a hand gun for anything that the boom won't get. I have no need for a "boomless nozzle". /forums/images/graemlins/wink.gif
Also, I'm one of these "can't leave anything alone" types. /forums/images/graemlins/smirk.gif /forums/images/graemlins/crazy.gif When I bought the little FIMCO sprayer (for doing spot spraying only) I started in on it no sooner than it was home. First off, I installed Tee-Jet "no-drip" 10psi check-valve nozzle bodies. Then I added soleniod valves to be able to shut off sections of the boom. I can use left, right, or center sections independently of each other now. /forums/images/graemlins/grin.gif
I do some spraying "for hire". That requires license, and subjects me to periodic inspection. The current gripe that most state AG inspectors have is dealing with wind drift. The "multi-nozzle boomless heads" are proned to drift issues. For that reason, as well as the mere fact they don't do well with the applications I'm using a sprayer for, I don't want any part of them. /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
And on the flip side, they may be just what the doctor ordered for YOUR needs. /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
/ sprayers 101
Thanks everyone for the input. Looks like I'll go with the boom type and a spray gun.
/ sprayers 101
One last question, well two actually.
Can you spray fertilizer right after seeding? I put down 10-10-10 when seeding the first time after building the house. Just want to make sure liquid fert won't release to quick or something and burn the seed.
Can you get quick connects for the PTO pump hoses? I forgot to ask at TSC when buying the sprayer.
It would be nice to easily switch between my watering tank and the sprayer.
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
1997 Angler 220 Walkaround Boat with T/A Aluminum Boat Trailer (A66738)
1997 Angler 220...
2018 International WorkStar 7500 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A66736)
2018 International...
2013 CATERPILLAR D6N LGP CRAWLER DOZER (A65056)
2013 CATERPILLAR...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
2018 Lodal EVO MAG-20 20yd Side Loader Garbage Truck (A66736)
2018 Lodal EVO...
