Sprayer tank fill marks?
/ Sprayer tank fill marks? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
I just bought a FIMCO 40 gal three point sprayer and spent a couple hours putting it together yesterday. I'm going to have to figure a way to connect the electric next. It seems well designed and sturdy. Came with yellow Tee Jet nozzles. The tank has no fill marks to judge the amount of fluid in it. Even my little backpack sprayer has those.
My question is this: Other than filling it with 5 gallons at a time, and marking the level somehow, is there a better way?
/ Sprayer tank fill marks? #2
I have one of those that I use on the back of my Ranger. It's a symmetrical tank so 1/2 level mark is easy as is the two 1/4 tank marks. That should be enough resolution for pretty much anything you are spraying. I just use mine for 2,4D/atrazine and Roundup/2,4D/atrazine. Mine sprays ~3.1 acres on a full tank at 6 MPH with flood nozzles.
/ Sprayer tank fill marks? #4
Mine doesn't have markings either, so I marked it in quarters. I rarely use it beginning less than full anyway.
I don't know your specific use or setup, but be aware that Fimco makes a wireless plug and play switch to control the pump. My tank is in the loader bucket with a short wiring run to the front of the tractor. The wireless switch let's me control the pump from the cab without a lot of additional wire.
I saw that, and thought that was a cool idea. I don't have a cab, so (I think) the wired switch will work okay.
/ Sprayer tank fill marks? #8
Use the flowmeter that he showed from amazon , shut it off at 5,10, 15, 20 and so on, take 2 short pieces of tape and place them on the tank leaving a small gap where the water is in the tank and spray paint a line when paint dries remove tape and you will have a painted line on your spray tank at 5, 10 , 15 , 20 gallons and so on.
Problem solved! I called FIMCO customer service, and got right in... Turns out there ARE gallon markings molded into the tank. 10, 20, 30, 40, and halfway marks too. I just didn't see 'em. I just went out to the shop, found them, took a marker and highlighted them. Yay! :D
/ Sprayer tank fill marks? #10
If it’s a white tank, they are very hard to see. And yes, hit em with a Sharpie. Neighbor had an older yellow 25 gallon fimco and the scale was in an awkward location on the side next to the pump. Once you saw it you never forgot it.
/ Sprayer tank fill marks? #11
If not marked and you have access to a scale, water weighs is 8.3 pounds per gallon.
1993 Transcraft trailer (A64194)
1993 Transcraft...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
John Deere Quick Hitch (A64119)
John Deere Quick...
1R CULTIVATOR, 3PT (A64280)
1R CULTIVATOR, 3PT...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
