Sprayer sprayer pump question
/ sprayer pump question #1
tpic402
Northern Ky
New Holland 3415
Just finished refurb of 3 point sprayer it has a hypro 6 roller pump my question is when i shut off all the manifold valves the pressure drops to 0 psi it does build pressure up to 40 psi with the spray wand open, no liquid goes to bypass if i shut off all the maniflod valves. should a roller pump build more than 40 psi at 540rpm,should not all the output bypass if the valves are shut off
/ sprayer pump question #2
I have a Delvan pump. I don't think itgets above 40 psi with everything closed. I have to twist the pressure regulator (out/less pressure) to get it to recirculate in the tank.
exactly the answer I was looking for I am assuming your sprayer works fine,thanks I will now go ahead and build my boom. :D
/ sprayer pump question #4
I want to build my own sprayer, what do you all recommend..
Look on ebay or craigslist for used one with good pump and tank,building from scratch is expensive, bought mine on ebay 65 gal. 3 pt hitch,with wand and pump,(250) was working, another 100 cash to that for boom and other components still a big savings over scratch build
/ sprayer pump question #6
I dont know if that's enough pressure. I run a 7 roller hypro pump on my 60g 10' boom, 40 psi while spraying wth 7 11004 nozzles, easy. The regulator is holding it down by several psi at 40. You need atleast 20 psi on, 30 is better.
Wldlife, watch craigslist. They might be few and far between, but they are out there. I got my lil 60g 10' fimco sprayer for $300 with the pump.:thumbsup: New fimcos are $500 or 600 + a hundred (or a few hundred for a good one) for the pump. Dont think you can build one much cheaper.
I built a 60' 200g sprayer, hydraulic booms and electric solenoids for the boom. Time I was done, I might have saved $500 over a new sprayer. Not enough to pay for the time I spent on it.
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
2012 JOHN DEERE 700K LGP CRAWLER DOZER (A65056)
2012 JOHN DEERE...
2022 Kubota M5660SU (A64911)
2022 Kubota...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
EDCO SS18-20R Concrete Saw (A64912)
EDCO SS18-20R...
