Sprayer Sprayer mount... ?????
   / Sprayer mount... ????? #1
Dewser45
Helena, Montana
Kubota BX 25
Hi there..
Just curious if anyone has pics or can explain how the sprayer that bxpanded sells mounts on the bottom part .. Like where it hooks to tractor hitch. Many thanks in advance
   / Sprayer mount... ????? #3
Did you take a look at the Sprayer Installation video on their website? If that doesn't have the info you're curious about I've found them very responsive to email questions.
   / Sprayer mount... ????? #4
I have the BXpanded sprayer for my Kubota 2360, have been very happy wtih it after several uses. I'm not clear if you're referring to the quick-on piece that mounts to the tractor, or asking how you attach the sprayer to the quick-on mount.
The quick-on mount has a fixed pin on the bottom which fits very easily into the pin hitch hole at the bottom of the tractor. The top of the mount is attached to the tractor via the top link mounting hole on the tractor; you use your existing top link mounting pin.
After you have the mount attached to your tractor, the sprayer has a fixed piece on the bottom that slips onto the mount; the BXpanded mount is made only for the BX series, so it's an exact fit on the tractor. One pin hold it together.
The BX mount also fits their "carry-all" which I bought; its an 18" X 32" metal platform which can carry simple tools, bags of fertilizer, etc. Haven't used it much yet.
Have had no problem with the mount; used the sprayer several times, it is sturdy even when filled with 25 gallons of water/herbicide, and easy to remove.
Hope this helps.
Ken
Thanks for the reply... I am curious as to how with just one pin and the mount on the hitch it keeps it from moving or I guess swinging back and forth a bit, especially when tank is full...
   / Sprayer mount... ????? #6
The top link mount is square to the bracket, and wtih the top link pin inserted has little/no sway. The bottom pin gets a little help with a welded "L" shape at the back which sort of fits behind the pin hitch and keeps it from swaying beyond maybe 1 inch or so. It's not tight, but the sway is pretty minimal.
   / Sprayer mount... ????? #7
Hi there..
Not sure what your plans are, but i am in the progress of building a similar setup...
sprayer build
   / Sprayer mount... ????? #8
Is that a bar inside a pipe or a solid bar machined down?..
Would of emailed you back but the tractorbynet pages would just bring up the home forum page...
I have all the dimensions for every piece i used if anyone wants...
I used 1-1/2 solid SS round stock and 1-1/2 pipe for the bottom bar. The 1-1/2 pipe is 12-3/4 long and the 1-1/2 solid stock i cut 2 pieces 2-1/2 long. I had to very slightly shave the inside of the pipe because on rolled pipe there is a slight flat spot where the pipe was weld, so just a slight shave is all that is needed for the solid stock to fit nice and snug inside, then welded.
This was the material i had available to me for free, so that is what i used. You could just use any round stock that is 1-1/2 od to fit in the hooks for the backhoe. Dont even need the oustide pipe. I just figured that a 1-1/2 id pipe would be a little lighter than a 16" solid stainless steel 1-1/2 stock would be. If i had aluminum stock i would of made it out of that.
That would be great if you could send me all the dimensions.. That would be very cool... My email is dewser45@yahoo.com Thanks a million
1000 Gallon Fuel Tank (A50121)
1000 Gallon Fuel...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Case 530 (A50121)
Case 530 (A50121)
2005 Cat DP40KL Forklift (RUNS) (A50774)
2005 Cat DP40KL...
2015 Freightliner M2 106 26ft Box Truck (A50323)
2015 Freightliner...
