Sprayer Sprayer Lubrication
   / Sprayer Lubrication #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I have seen where several users have mentioned lubrication of their roller pump 3 pt sprayers between uses. How is that done and with what lubricant??
   / Sprayer Lubrication #2
Water pump lube... You can get the stuff that goes in pressure washer pumps for storage. Guess you could also put in a little eco-safe propyl-glycol based antifreeze between uses, and then flush out.. AF mixes have water pump lube.. etc.
soundguy
Didn't know there was such a thing as water pump lube. Good info. Thanks
   / Sprayer Lubrication #5
The guys down here run a 50/50 mix of antifreeze.
D.
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2019 John Deere...
2005 Mack CV713 Granite T/A Roll-Off Truck (A50323)
2005 Mack CV713...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
