Spray Welding, anyone?
/ Spray Welding, anyone? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
I came across this video and found it quite interesting. It is long and I learned a lot that I will never need to know... but I stuck it out. Maybe this is ho hum for some of you but I thought this guy did a great job executing and teaching.
SNS 3: Spray Welding a Blower Shaft - YouTube
/ Spray Welding, anyone? #2
I agree with everything you said, I was waiting for a logging video to show up, I used this for filler material so I watched the whole thing, he's not only talented he's a great teacher, must be nice to be gifted.
/ Spray Welding, anyone? #3
He still does a few things around the shop but I liked his videos better when he worked for a living. :) And I hate when he stretches a 1-hour job into two videos over two weeks. :cool:
/ Spray Welding, anyone? #4
Interesting, always nice to watch a craftsman doing a good job.
/ Spray Welding, anyone? #5
Very interesting process, long video but it keep my interest to watch the full video.
KC
/ Spray Welding, anyone? #6
We had a spray weld setup where I worked and it was handy on bigger shafts like blower shafts. It is very messy so you do want to cover your lathe before spraying. I'm not a fan of the old cemented carbide tools VS nice sanvik finishing tools with inserts to get a nice finish and size. The spray will give you a nice finish but you need the surface speed and correct insert to get it.
/ Spray Welding, anyone? #7
I first thought the video title was going show welding like they do on crank shaft rebuilding but he seemed to think welding is not a good option because of heat movement, he might be right on heat movement on metal. I know on welding and or burning that I do, steel moves like crazy, but it works on crank shafts and they are just as critical as that shaft he was powder welding, wonder what the difference is, I always thought heat was heat.....
/ Spray Welding, anyone? #9
Oh, that's a long one. I know zero about spray welding, but then again I know zero about anything without google/youtube. :D
/ Spray Welding, anyone? #10
Least it's not minus zero.......
/ Spray Welding, anyone? #11
spray welding is a pretty common practice in large machine shops that do a lot of industrial work. Back in the 70's doing large industrial machine repairs most machines with insert bearing shells did not offer undersize inserts for turned down shafts and other applications. We had very good results having shafts restored to factory spec. rather than replace them. Saved customers much $.
Ron
/ Spray Welding, anyone? #12
I've done a ton of spray build up and hard surfacing. I have both Hot Spray and Cold Spray equipment and a crap load of assorted powders. Used to sell the stuff for many years. Still my favorite way to repair Cast Iron. Fun Stuff.
/ Spray Welding, anyone? #13
There are 2 processes for spray welding. The best for shafts would be cold spray. It's 850 degrees or less. We used temp sticks to make sure we didn't go over 850. You can't get in a hurry. At 850 the shafts don't move much and the powder is formulated to be applied at that temp. Hot spray is great for cast iron repair or hard surfacing.
It does look like fun and would be a blast to try. Old school 'additive manufacturing'.
/ Spray Welding, anyone? #15
Check out the Victor or Stoody Spray Powder set. ( Hot Spray ) The vids on it are terrible and wayyyy too hot. We used to sharpen lawn mower blades and then a light coating of hard surface on the back. Never sharpen again if you don't hit rocks. The blade metal wears with use and the blades sharpen themselves. Great on thin cast too.
/ Spray Welding, anyone? #16
I been around welding the last 40 years and just heard about powder welding on cast last year, that was a first for me and now I see it done on steel shafts, less heat is always good. I suppose JB Weld is out of the question, thats at room temperature.........
/ Spray Welding, anyone? #17
That Adam's a good kid, fair machine hand and a fine representation of his dad and grandfather. I believe he also has 20+ years under his belt as a fireman too. Got some good skils and wiling to learn too.
The O/A spray deal is either somethin you do regularly or a skillset you loose. Had a Castolin set years back but didn't have de work to pay the learning costs.
Before de powder process there was a AC arc process wid "special rods" supposed to do the same. It didn't. Real good way to screw up a lathe though.
/ Spray Welding, anyone? #18
My father told me about it in the 60's at Ford stamping plant they were using it on the punches in the dies.
/ Spray Welding, anyone? #19
Pretty good video of de whole job usin the single powder process wid a Victor torch.
Oxy fuel shaft build up - YouTube
I got no idea why dese guys do't better shield de lathe & chuck with some sheet metal for machine protection.
/ Spray Welding, anyone? #20
I worked for a company that did that as well.
They would take a crane and just rebuild the thing from the ground up, using that to build up the spools of the winch drums and whatnot. It would take them a year to rebuild, with lots of money in put into the crane, but it was cheaper to bring them fully back to spec then it was to buy a whole new crane.
I am not sure if they still do that or not, (they might lease cranes now instead),but on my tractors and vehicles, it is a practice I have adopted and has saved me a lot of money over the years. But I am a person that likes functional and do not need shiny things.
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
2011 MAGNUM PRODUCTS COMBO UNIT GENERATOR/LIGHT PLANT (A60736)
2011 MAGNUM...
Jack Daniels Mini Decorative Truck (A61569)
Jack Daniels Mini...
TANK MANIFOLD (A58214)
832541 (A61166)
832541 (A61166)
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
