Spray for Pasture Weeds
   / Spray for Pasture Weeds #1
jay3534
zebulon nc
AC 5015
This year I have had poison sumac spread over about 4 acres of well established pasture. Any recommendations for a pasture herbicide would be appreciated. I don't want to lock dogs or horses out if possible.
   / Spray for Pasture Weeds #2
Remedy is what I've just started to use with fair results. I need to work on my spraying technique, but think it will clean up the pasture in a few years of spraying it. Grazon is also supposed to be pretty good. The important thing after figuring out your mixture and how fast or slow to drive while spraying is when to spray. The instructions will say when it's the best time, which is usually late spring when the plant is actively growing. Summer is usually the wrong time to spray.
Remedy(R) Ultra Herbicide — Pasture Management
   / Spray for Pasture Weeds #3
That Remedy Ultra that Eddie mentioned is some good stuff, I've been killing briars and small trees with it the past 2 years in fields. It is also some dangerous stuff, don't get it on you if you can help it.
   / Spray for Pasture Weeds #4
Remedy is Triclopyr 60.45% and inert ingredients. This is as strong an herbicide as you can buy over-the-counter.
No label directions for mixing in one or two gallon quantities.
I use Remedy with caution, mostly along fence lines. Unlike 2-4d, Remedy works primarily on roots. Therefore ground should be moist or rain expected at time of Remedy application.
I would have horses and dogs out for eight hours after Remedy application, myself. I am cautious.
( I do not have Sumac here.)
   / Spray for Pasture Weeds #6
   / Spray for Pasture Weeds #7
Remedy worked well on on scrub oak and other broadleaf weeds in my rocky pastures. If I remember correctly, there's a time listed to prohibit grazing, like two weeks. (?)
Was pretty pricey though...
Any and all recommendations will be looked at
New/Unused 20ft x 30ft x 12ft Storage Shelter (A44391)
New/Unused 20ft x...
2012 INTERNATIONAL 4300 CAB AND CHASSIS (A43004)
2012 INTERNATIONAL...
2017 Ford Explorer AWD SUV (A42744)
2017 Ford Explorer...
2006 STERLING LT9500 SERIES CHEMICAL TRANSPORT TRUCK (A45333)
2006 STERLING...
YANMAR VIO17 MINI EXCAVATOR (A45333)
YANMAR VIO17 MINI...
2011 CHEVROLET EXPRESS VAN (A45046)
2011 CHEVROLET...
