Sporadic/ no hydraulics to the hoe
   / Sporadic/ no hydraulics to the hoe #1
jbwbhs
graham nc
deere
New here, been learning a lot lurking, first post. They delivered a DK45 HST today got it off the truck, everything appeared to function as it should so I tackled the manuals (first tlb for me). Went back out to run it thru full cycles to warm everything up (as per the BOOK). The FEL worked fine, went to lower the outriggers and they wouldn't lower. Swivel lock, boom lock and leg latches off, increased rpm to 2200 or so tried again. Got the legs down, but they only moved with partial control input, couldn't get any action from the boom, stick or bucket. (Funny it worked just fine off the truck). Checked all the fluid levels, worked the fel again (fine), tried to put some strain on the hst (minor, the legs were down) nothing. No leaks at the hoses or fittings, everything appears sparkling new. A shame it doesn't work.
Just guessing, maybe the hydraulics need bleeding? Never seen anyone mention that ??
Or have I forgotten something really stupid?
   / Sporadic/ no hydraulics to the hoe #2
Check the quick connects that attach the input and output to the tractor. Might not have been fully seated and vibration has moved them jet enough to be non-functional. Failing that, my next call would be to the dealer.
   / Sporadic/ no hydraulics to the hoe #3
On my 3037 the hoe goes to the right hand blue port and the return goes into a fitting on the axle. Is yours like that?
Got it right, like I figured, an operator malfunction. Thanks,tho.
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
Yamaha Wave Runner Jet Ski (A53117)
Yamaha Wave Runner...
