Spool Valve Part Number Question
   / Spool Valve Part Number Question #1
LarryS
Phillipsburg, Ohio
MF GC2300
I have a Nimco CV422 loader valve (no PB). I looked up the part numbers and found:
O ring/spool seal part number of 71513155 which Jack's sells for $49.40
complete seal/set kit part number 71512160 for $46.27.
I have a hard time understanding why the spool seals cost more than the entire kit if the spool seals are included in the kit. Can someone explain? Or are the spool seals not included in the "complete kit". I'm giving up on the regular O ring approach found in previous posts. Seems like I can't keep it from leaking even after two O Ring rebuilds. Don't think the bores are scored either. Just thought I'd try parts that are meant for the application.
Thanks in advance!
Larry
2015 International DuraStar 4300 Crew Cab Mason Dump Truck (A48081)
2015 International...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2013 Chevy Silverado 2500 HD (A51039)
2013 Chevy...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2025 KG45 UNUSED U-Type Screw Pin Shackle Set (A50860)
2025 KG45 UNUSED...
