Splitting/Breaking Large Rocks
/ Splitting/Breaking Large Rocks #1
AndyH
Ford 1220 4WD HST; John Deere GT235
I'm wondering if anyone has had much experience splitting or breaking up large rocks which are too big to move with their tractors. I've split a lot of smaller stuff (up to say 3x2x2 feet) by drilling 3/4" holes in a line using a small rotary hammer, then cracking them with 4" feathers and wedges driven into the holes with a sledge. However, I'm currently trying to remove a larger boulder that's right in the middle of a path I'm constructing (and unfortunately, I can't simply reroute the path). This thing is at least 6'x4'x3', and the wedges aren't splitting it.
I've spoken with local rental yards about using a larger jackhammer to break the boulder up, but they didn't think it would work; although I can very slowly chip away at the rock with a chisel mounted in my rotary hammer, it's much harder than concrete. The rental guys suspect the steel in their jackhammers would just mushroom when used on solid rock.
A sledge hammer doesn't make much of an impact either; at best, I occasionally get some chips loose, but it would take months to make any real progress.
I checked with masonry tool suppliers; they've got larger feather and wedge sets (1" to 1 1/2" diameter, and up to 24" long), but I'm not sure how I'd ever drill the holes for those (they definitely exceed the capacity of my 7/8" rotary hammer).
Anyone got some suggestions? One of the rental yards mentioned using "Bentonite" (sp?), an expansive compound you pour into holes to crack the rock. They didn't carry the stuff, however, and didn't know who might. My other idea was to excavate beneath the edge of the boulder, then try to gradually raise it with larger hydraulic bottle jacks, and eventually tip it to the side of the path. Not sure how safe that alternative would be.
Thanks for the help.
AndyH
/ Splitting/Breaking Large Rocks #2
Don't know the situation, but have you considered the big hole and rock disappearing trick?
/ Splitting/Breaking Large Rocks #3
You've demonstrated the ability to drill holes in the rock, and if I remember correctly, you live in Vermont? Freezing weather should be upon you shortly. Drill holes, fill with water and plug the hole, let the water freeze and it will expand, cracking the rock. If time is critical, then I'd suggest a pro with dynamite, it is not something to do yourself, unless you are very experienced in blasting.
/ Splitting/Breaking Large Rocks #4
AndyH, There is only two practical methods that I know of.
One would be using a backhoe with a hoe ram mounted. And the second is the method Scruffy brought up, a blasting agent. Needless to say the first method is the safest.
ErnieB
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2017 FREIGHTLINER M2 TRASH TRUCK (A67714)
2017 FREIGHTLINER...
PORTA POTTY (A68842)
2017 Kenworth T880 T/A Galbreath Roll-Off Truck (A66736)
2017 Kenworth T880...
2018 32ft Forest River Lacrosse 3211RK T/A Travel Trailer (A66738)
2018 32ft Forest...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
