Splitting a 175 - suggestions
   / Splitting a 175 - suggestions #1
kf5ewr
Sayre, ok
Massey Ferguson 175
Looking for suggestions.
I have a 1974 MF175 diesel.
The pto clutch isn't working anymore. The engine portion is working. I can push the pedal all the way to the floor plate but the pto doesn't disengage anymore.
I'm guessing it's time to split the tractor and replace the clutch. Splitting it is beyond my mechanical abilities so time to call a mechanic.
What else should I have the mechanic replace if I'm already paying someone to split it?
Everything else mechanically seems to be in working order. But, thought there might be some preventative stuff that should be done while it's split.
Thanks
   / Splitting a 175 - suggestions #2
rear main seal along with the clutch job and Have the flywheel turned .
   / Splitting a 175 - suggestions #3
You should check pedal and check clearance for the PTO clutch before you splitt
   / Splitting a 175 - suggestions #4
Yes, certainly determine what is wrong before starting this sort of job.
If the clutch won't drive - its friction plate is worn, its pressure plate is faulty, or it is out of adjustment.
However, if the clutch won't release ... pedal adjustment, or second release setting, is usually the only fault to cause this issue. It can be adjusted from the outside.
This thread may help: Read from Post #23 to the end ... 2nd clutch release is the issue here.
https://www.tractorbynet.com/forums...age/386797-mf-135-power-outlet-problem-3.html
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
Electric Mobility Scooter (A51694)
Electric Mobility...
John Deere D105 Auto Riding Mower (A53117)
John Deere D105...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
FAKE (A52472)
FAKE (A52472)
