Splitter Build Begins
/ Splitter Build Begins #21
What is the GPM of your PTO pump, and the model #? Is it a 540 or 1000 PTO rpm speed.
It's 540 rpm but I am not sure of the model it's on the tractor can not see good. I put a log on the four way my grand daughter pulls the lever I turn to get another and she is waiting on me. I believe that is super fast. If I have another person then we can keep up. Thank J.J later
/ Splitter Build Begins #22
I had another design thought... Work Lights. If someone already mentioned that I missed it. It get dark early in the winter when you're most likely to use a wood splitter. having some work lights handy would increase your options for when you can split wood.
Does your engine have a charge circuit for a battery?
Funny you should mention that because I was tossing that around last night. It does have a system to charge and the light system is definitely a go for the build. Also I just spoke with the local commercial firewood Company and they offered me $50 per ton for busted unseasoned wood 15 inches long only restriction is no box elder, no sycamore, and no more than 15% popular. What do yall think?
/ Splitter Build Begins #24
That's a good deal. I can do 5 ton a day and not hurt my self. The rest of the wood can trash out to people who burn any thing. They make the mistake on popular that and ash is my biggest seller. My customers like pretty wood and clean.
/ Splitter Build Begins #25
Some of the features I like from my own splitter are:
* work tables to catch the wood so you don't have to lift it multiple times.
* 3-point mounted so it raises and lowers, allows me to lower and roll on a big one using an old car ramp as a helper, then raise up to the perfect height so I am not bending. that height may change during the course of the day, and certainly changes depending on who is splitting. Even if it has its own engine, this idea may be considered.
*consider making the splitter rotate to vertical too
Here's a thread talking over much of these ideas, and pics of mine are in there:
http://www.tractorbynet.com/forums/attachments/146167-powerhorse-3-pt-log-splitter.html
Honestly if I was starting over I'd reconsider hydraulics altogether. These new mechanical ones are more economical to run and are faster too...
DR Power Equipment - RapidFire Splitter Gallery
DR is one supplier, there are others but I forgot them.
I look at the mechanical splitters also and to be honest they kinda scare me not much time for you to get a finger outta the way.
I think we are very close to our final design here is where we are so far.
Splitter;
Tow-able built on 4x8 trailer cut to fit work areas.
Sled with push block on 6x8x1/2 H beam
Power-16.5 BS
Hydraulic-28 gpm 2 stage
Cylinder-5"x2"x24"
Wedge-Hyd. adjustable 1 or 4 way
Accessories;
Log Lift
Tube type work tables
Work lights
Paint-Black an Red labeled TBN#1
Still needed;
Best way to couple pump to engine
Suggested tools
Filter inline versus tank screen
Hyd tank size
Being considered;
Tempest type wedge bed
Multi piece chuck bed tipped with log lift
I have made a few drawings I will post later this evening I hope. Plan is to start the build next weekend so lets here any other ideas you fine folks have.
Here are the drawings feel free to critique them with anything that should be different.
/ Splitter Build Begins #28
nice idea.. Your controls way over there will be making you twist lots.. You will be facing the ram to watch the wood.. you will want your controls near the ram..
Thanks Its just a mock up I will have to tinker with the location of the controls but over all I like the design
CFG Industry 680 QA Hydraulic Breaker (A60463)
CFG Industry 680...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2018 FORD TRANSIT 350 4X2 CARGO VAN (A59906)
2018 FORD TRANSIT...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
