Split tractor = new hydraulic fluid + filter?
/ Split tractor = new hydraulic fluid + filter? #1
moojamboo
Bronze Member
Nothern Vermont
Ford 1710
Hey all,
'86 Ford 1710 696 hours
New to me tractor as of this Feb. Before winter comes getting a handle on routine maintenance history, some of which we don't know completely.
We do know a new clutch was put in Jan 2010, at 650 hours. I am about to hit 700 hours. If someone was putting in a new clutch, and splitting the tractor, does that pretty much mean they likely changed hydraulic fluid and filter? Is there any way to split tractor without affecting hydraulics?
I'd like to build my hydraulic maintenance schedule off of a 650 hours start point if possible, wanted to get crowds opinion of what likely happened when new clutch went in / tractor was split.
thanks,
/ Split tractor = new hydraulic fluid + filter? #2
No. The clutch is in the bell housing between the engine and the transmission which is a dry area. Don't expect any fluid change due to the clutch work.
/ Split tractor = new hydraulic fluid + filter? #3
That's correct. The clutch does not affect the hydraulic system.
/ Split tractor = new hydraulic fluid + filter? #4
I'm going against the grain here (surprise). Splitting a 1710 will require draining the hydraulics as the suction tube needs to be removed. That doesn't mean the oil was replaced or poured back in, nor does it mean that the hydraulic filter was replaced. No way of knowing.
John Deere 8245R (A64119)
John Deere 8245R...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
