Split-Fire splitter
   / Split-Fire splitter #1
zmjc
Eastern Ontario
L3800HST
Hi all,
Does anybody have good experiences to share with the Split-Fire 3403 bi-directional 3PH splitter? The 3403 has the 4-way knife. It's the only bi-dir 4-way that I've come across.
I want to use it on my Kubota L3800HST, which has 6.3 gpm max on the implement pump. Is that enough?
I don't think I can justify the cost of their standalone units...
   / Split-Fire splitter #2
Hi all,
The right flow in GPM's, is the flow that will let you operate the splitter safely. If you purchase it, then you have to accept what it is. You can figure out the cycle time by knowing the size of the cyl and GPM's. You can also determine the push and pulling force, knowing the pressure and size of the cyl.
https://www.surpluscenter.com/techhelp.asp?catname=hydraulic
Select Calculators, then Force and Speed.
   / Split-Fire splitter #3
I have a Split Fire 3203 with my Case IH DX-33.
The flow is around 6 gpm and I get more than enough power. I splitted 24 in. diam maple logs with ease.
With a small flow you only get slower speed. I use it at 2000RPM and the speed is good enough for my back and safe use.
I an quite pleased with the unit.
Pierre
Thanks Pierre, I appreciate the real-world feedback.
The cylinder volume is almost exactly 1 gallon, so that makes the calculations easy... One uni-directional stroke in 10 seconds, a complete cycle in 20 sec, at max rpm / 6 gpm, I guess...
   / Split-Fire splitter #5
The return/retract stroke is faster due to the shaft taking up space, less fluid. The extend stroke has more power.
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
2010 John Deere 648H Grapple Log Skidder (A50322)
2010 John Deere...
2006 Mack CT713 Granite T/A Galbreath Roll-Off Truck (A50323)
2006 Mack CT713...
Frontier AB13D Hay Spear (A50120)
Frontier AB13D Hay...
JMR Attachments Tree Boom (A50121)
JMR Attachments...
