splined adapter for a 9 tooth window lift motor ideas??
   / splined adapter for a 9 tooth window lift motor ideas?? #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
just wondering what a guy could fit over a window lift motor that is a 9 tooth , so I can hook that (weld prob) onto a snowblower chute crank arm? Its a 70's ford one,, I read a post somewhere where someone used a Ford one, so thats what I used.. thanks
   / splined adapter for a 9 tooth window lift motor ideas?? #2
You could drill a hole in a piece of metal so it would slip over the gear and put a setscrew in it.
   / splined adapter for a 9 tooth window lift motor ideas?? #3
I used an old socket that fit the gear. Then I got some square stock that I welded to the crank arm.
   / splined adapter for a 9 tooth window lift motor ideas?? #4
You could make your adapter (welding, what not) and then bore the center to the OD of the splines and JB Weld that on.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
Cat TH407C Telehandler (A52748)
Cat TH407C...
John Deere 310A Loader Backhoe (A52384)
John Deere 310A...
ROCK PICKER (A52472)
