splicing in hydraulics
/ splicing in hydraulics #1
Cord
Richfield, Wi
Resident Architect
When you add a loader to the Yanmar tractors, most people have been cutting the supply and return lines between the pump and the transmission. This is fine for a gear shift model, but I have a power shift transmission and I'm a little leary of doing this. I'm concerned about reducing the pressure to the clutches causing them to slip resulting in damage. In theory this could be a problem as the clutches will need full pressure to push the loader into the pile at the same time the loader needs full pressure to scoop. The solution would be a dedicated loader pump, but this isn't a easy install. How many members out there use their power shift tractor and loader? I'm not talking about mowing grass with a loader attached, I'm talking about really working the tractor and loader.
I know that Yanmar installed loaders on their American tractors, but again they were all gear shift models. Does anybody know how Yanmar plumbs the loaders on their powershift tractors? Pics? Documentation?
/ splicing in hydraulics #2
Cord,
I have plumbed power shift models for a FEL install. There was no noticeable difference from before and after. Using an open center controller simply extends the pressure in the loop and the return line is not required. One splice only and it worked flawlessly.
Mark
/ splicing in hydraulics #3
</font><font color="blue" class="small">( I know that Yanmar installed loaders on their American tractors, but again they were all gear shift models. )</font>
Not correct, Yanmar sold Powershift models new in the US.
I had a loader plumbed via splicing the hydraulic supply line on an FX26D and a YM2610D, both were powershift models and I experienced zero problems and believe me, I worked those tractors.
/ splicing in hydraulics #4
I'll second Brent and Mark for having my loader plumbed this way and no problems noted. With that said I don't know what the pressure is down stream of the loader control valve when the valve is directing fluid flow to the loader. Also don't know what pressure and flow is needed to keep clutch/bands on the powershift from sliping. I wouldn't think it anywhere near the peak pressure of about 2k psi or flow rate the hyd pump can provide.
I think you hit upon my concern. Nobody really knows. That's what was bothering me. I was hoping to have more members post here saying they have a power shift tractor and nary a problem.
How about this question...anybody know what the hydraulic output and pressure of the little 1110d's pump is?
/ splicing in hydraulics #6
I believe that is what Brent was saying, nary a problem. He may not have them now, but did and worked them hard, and didn't have a problem. Does it matter that he had and don't have now?
/ splicing in hydraulics #7
I have 4 different models of Yanmar and they all are Power Shift, YM146,YM187,YM226 and YM336. All these models have two pumps; one internal pump for the Power Shift and one on the side of the engine for loader/ three point hitch. So you don't need to worry about starving the clutches. What model tractor do you have? Somebody must have a parts or service manual that tells how many pumps your tractor has.
I have a 1110d. So the power shift clutches are driven by a internal pump? I had assumed they were driven off the engine pump. Is anybody able to confirm if the powershift tractors have a second internal pump? If there is truly a second pump on my tractor, then my concern has no foundation-that would be awsome.
/ splicing in hydraulics #9
I have all US & most Japanese parts books. All powershift models have an internal powershift pump that is driven directly by the clutch shaft. The US models with Yanmar loaders were plumbed with the loader inseries with the 3 point. This is just the same as cutting the line & installing the valve in series. You aren't going to starve the powershift transmission. It uses a very small amount of oil to engage the clutches.
Well there you go! Now, were is my pipe cutter? /forums/images/graemlins/grin.gif
Mark- your comment of "open center" control valve got me thinking. When I look at the valve that came with the loader, it was intended to be run off a dedicated hydraulic pump. The pump supplied the valve and then the oil returned to the tank. I'm certain that this valve does not have a "power beyond" capability, but I don't know exactly what a "open center" valve is. Why wouldn't I need a power beyond valve?
Guess it's a mute point now. I cleaned off the lable on the pump and found that it displaces 3 cc per revolution. That cross references to .183 cuin/rev or .000792 gal per rev. Assuming the pump turns 1:1 that would give me a max rpm of 2600. This equates to...2 gallons per minute. That looks about right. So I have 2"x26" lift cylinders. Using a on-line hydraulic calculator I have a 38 second lift cycle speed. I'm thinking a external hydraulic pump might be in order here.
/ splicing in hydraulics #13
It would be cheaper to buy 1" cylinders than an external pump. Even one 1" cylinder can lift more than you tractor will ever be able to handle let alone 2. Also the 1" cylinders are much lighter than the 2" and if you want to pick 100 lbs with the bucket you will need to keep the total loader weight less than 200 lbs. Dropping to one cylinder on the bucket will help with weight also.
Open center is what you need and a power beyond for your application is not needed. Your valve will be in series with the constant flow and divert it to the cylinders when you activate it.
Buck
/ splicing in hydraulics #14
Any one know of an online source for metric to standard hydraulic fittings and adapters. My tractor has a 14mm 1.5 pitch thread that I would like to splice with a #6 line T
Try Baum Hydraulics. They seem to have a pretty good selection parts.
2014 Talbert T4-55CC-HAG-T1, 55 Ton Detach Lowboy (A62679)
2014 Talbert...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
