Splicing a water line
   / Splicing a water line #11
The bread does not work very well, nor does the product called "plumbers bread", A synthetic bread product made for this purpose. if you have to work on pipes with water in them there is a tool called a jet swet that plugs the pipe so it can be soldered etc. Just drain or blow it out and you will only have to do the job one time.
   / Splicing a water line #12
I have seen but never used a clamp on pcv "T" that you glue to the pipe you are tapping then drill through the "T" and glue to it. I think Home Depot has them.
Cary:cool:
   / Splicing a water line #13
ALHILLDIRT said:
I have a 3/4" pvc cold water line and a 3/4" cpvc hot water line that I need to tap into for supply to a small sink. I have fair access to the lines. These are main supply lines with an operating average pressure of 55 psi.
My question: Is there a secure way to tap into these lines without cutting the line and installing a "T".
Shark Bite 3/4 inch Tee.
Quick simple easy.
   / Splicing a water line #14
Just .02 worth, as long as it is going to a faucet, might as well put in the shutoff (i like the lever ball cock ones instead of the ones you have to turn to turn off) as well as the T. Get the good hose clamps, just blew a pipe off last nite trying to 'get by' with the cheapies had laying around. Even the dog got a shower! Fortunately was in the basement and by a floor drain so just the floor got a good washing.
   / Splicing a water line #15
Cary:cool:
Same thing I was going to suggest. I've never tried them either, but thought they were a really neat idea when I saw them in McMaster-Carr.
PVC Pipe Fittings & Pipe
   / Splicing a water line #16
If you are worried about water you can use a waterproof glue, it is usually blue, you get most of the water out of the pipe and then apply the glue, it takes longer to set up but 15 minutes ought to be fine.
The only thing I am not sure about is if it is rated for cpvc, when I repair or change a pipe I won't use the normal clear glue anymore.
   / Splicing a water line #17
You might want to check the drying time for it. If I remember correctly but I am not sure the blue glue is actually the one with the fast set up time because it is made to use where there is water in the pipe
   / Splicing a water line #18
RalphVa said:
That white bread trick is generally only used to keep the water from cooling off the pipe joint when soldering. Just catch the drips in a bucket from a plastic pipe.
I agree with the others. Just blow or drain the lines and cut them and put in tees. Make sure you have the correct PVC/CPVC tees. They're slightly different size. You can even use a copper pipe cutter tool to make the nice cuts. Just make depth changes slowly. If access is good, I generally use a little circular saw (18v Dewalt) to make nice cuts on pressure pipes. If low pressure, I just use a hack saw or sawsall.
Ralph
While sorta correct, it is used 'to keep the water from screwing up the joint' for whatever reason, e.g., on plastic pipe, the glue does not like wet surfaces. I have used it both on copper and plastic.
Harry K
2007 Ford F-150 (A55973)
2007 Ford F-150...
Portable Restroom (A54865)
Portable Restroom...
2002 TRAVIS BODY & TRAILER, INC. 48 END DUMP TRAILER (A58214)
2002 TRAVIS BODY &...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56435)
2002 Chevrolet...
