Tires spinning tires BAD thing to do
   / spinning tires BAD thing to do #11
A few stump here and there may not hurt, but my Loader has a nice "drooling lip" where a buddy ( honest) decided to remove a few stumps. Pins will break and get sloppy real quick after a decent size stump or two. Just use caution and if lots of stumps are in your future get the BH. Also NEVER let a buddy remove stumps with it......
   / spinning tires BAD thing to do #12
I have a droopy bucket from stump removal as well. Not really bad, but bad enough that when it comes to replacing the wear-edge, I'm probably going to spring for a whole new bucket.
Having removed stumps both ways, a BH is absolutely no question the way to go. I totally agree that you CAN remove them with only the loader, but it has two major negatives:
First, the "area of destruction" is many, many times greater with the loader...while the BH is almost surgical in that you are basically creating a 1' wide trench around the tree in question, the loader requires you to dig down on the sides with 4' wide swaths. Then you're pretty lucky to cut through roots, so you're down there with the axe an awful lot. And good luck if you're on a Pine with a good tap-root network.
Second: The only way I could pull out root balls was get as many roots as I could, hook my tractor up to the root with my 12 ton strap, and start a-yankin'. It was VERY, VERY hard on my tractor and my wife watching me do it (along with the heavy manual labor) was a huge selling point in the BH.
If you only have 2 trees to take up and you've done one of them, I guess there isn't much of a reason to fart around with a BH for that task. In my case, I've taken 6 or 8 good size trees up a year for 2 years now on my property alone. And I've helped some other guys. My tractor would live a short and difficult life had I not added a BH. And it is SOOOOOOO nice for a great many other tasks.
Wolverine Skid Steer Drum Mulcher (A50515)
Wolverine Skid...
John Deere 603 3 pt Mower (A50514)
John Deere 603 3...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
UNUSED RAYTREE QUICK ATTACH VIBRATING BUCKET (A51244)
UNUSED RAYTREE...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
