Spindle Cover for Branson 4720h
   / Spindle Cover for Branson 4720h #1
Larry Meschkat
Graham, TX
Branson 4720h
Can anyone tell me the metric screw size for the PTO spindle cover on the 4720h. A buddy of mine borrowed my tractor, removed the cap to attach a mower, then returned the cap, without the screws. He said he lost the screws in the pasture. These are metric, but I'm not sure what size. Anyone know? I'm sure this is very simple, but I want to clean and grease the spindle, and re attach the cover. Thanks much to anyone who can answer this.
   / Spindle Cover for Branson 4720h #2
Are you referring to the plastic cover of the PTO shaft? I think it's M8x1.25. If it's the metal shield around the PTO, then it is either M10x1.5 or M12x1.75
I was referring to the screws for mounting the plastic cover for the PTO shaft. My friend removed the cover to connect a mower shaft to the PTO. He placed the cover in the tractor storage tray, but some how, lost the screws in the field. I need to clean the PTO shaft, grease it again, and remount the plastic cover to keep the shaft and grease clean. I'll try the M8 x 1.25 screw size. Thanks much for your timely reply.
   / Spindle Cover for Branson 4720h #4
The plastic cover is bolted with M8x1.25. The bolt head should be a 13 mm socket.
48" Pallet Forks  (A52384)
48" Pallet Forks...
Electric Mobility Scooter (A51694)
Electric Mobility...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
