spindle bearing #s Toro 52" deck
/ spindle bearing #s Toro 52" deck #1
laminectomy blues
Lakeside Ontario
2001 toro 522xi
Can anybody tell me spindle bearing numbers for Toro 5xi (52"0 deck, or point me in the right direction on the site. Thanks, Dave
/ spindle bearing #s Toro 52" deck #2
Don't specifically know about the "Toro," but the decks I've worked on have all been pretty much the same, and the whole arbors have mostly been throwaways. They are aluminum and attached to the deck with hardened, self-drilling, self-tapping, screws that fuse to the aluminum in the acid environment of wet chopped grass. I rarely get a screw out without it breaking off in the aluminum. They are nearly impossible to drill out, as they are hardened and brittle, and the drill wants to dance off into the softer metal and break. Likewise, the bearings fuse to the aluminum too, making replacement difficult. I've usually had to replace the whole arbor assemblies.
When I put in the new arbors, I drill the mounting bolt holes out, throw away the self-tappers, replacing these with stainless quarter-twenty bolts and lock nuts.
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
Truck Diesel Tank (A64119)
Truck Diesel Tank...
2019 KAUFMAN 46' STEP DECK TRAILER (A64280)
2019 KAUFMAN 46'...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2022 Ford F-150...
(8) John Deere Tractor Weights (A64119)
(8) John Deere...
211453 (A62131)
211453 (A62131)
