spike harrow before grass seed?
   / spike harrow before grass seed? #1
v8only
Mb
1988 John Deere 755
So if any of your remember my other thread turning weeds to grass I am finally going to start this fall.
I have sprayed one application of 24D, I am getting a 5 section harrow for $20.00 and I plan to run the harrow around my weed/grass filled 4 acre property to rough it up a bit so the grass seed has a place to sit over winter and come time spring the snow melt will aid in wetting the seed.
My question is will the harrow break up the yard to much or just right? how much should i rough it up?
   / spike harrow before grass seed? #2
You do not want more than a slight dirt cover over grass seeds, so not too rough.
Where is "Mb?"
   / spike harrow before grass seed? #3
Should work fine. Rolling it after seeding would help set the seed a little better and keep it in place. What you are talking about is "dormant seeding", leaving it over winter. I think this will work OK if you have a consistent cold winter. It would worry me if your temperatures bounce around a lot over winter.
MB is Canada. My winter is -40 degrees celcius with 2-4' of snow cover all winter.
Okay so just rough it up a bit maybe 2 passes one each direction?
2009 SolarTech Silent Messenger III Solar Message (A53117)
2009 SolarTech...
1987 Ford F800 E-One Pumper Fire Truck (A51692)
1987 Ford F800...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2002 14ft S/A Utility Tilt Trailer (A51694)
2002 14ft S/A...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
SET OF (3) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (3) ALCOA...
