SPIKE AERATOR VERSUS PLUGGER CORE AERATOR
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #21
Re: SPIKE AERATOR VERSUS PLUGGER CORE AERATOR
<font color="red">Should I weld or bolt the spoons on or maybe screws? </font>
I'd think that would depend on which will cost your more time and or money. i.e. Do you have to change them out often or not?
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #22
I would weld them on, if you own a welder. If you designed the unit, do what ever is easier for you. If you bolt them on, use grade 5 or 8 bolts.
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #23
Bob,
The resurrection of this thread only reminded me of my own little debacle with core aerating that I posted way back in the thread. The aeration worked fantastically, but let me just say: "Call before you dig" /forums/images/graemlins/grin.gif
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #24
That's because the phone companies (and cable companies, I might add) aren't that concerned about non-feeder lines. If it was fiber it would be a totally different story. About 20 years ago my Dad did the same thing to the phone line but he was using a handheld weeder while going after the dandelions. What are the odds that he'd get the phone line doing that way?? Guess it's just bad luck!
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #25
cqaigy, I don't know if the have to be changed often or not. I have never had a core aerator. I borrowed a neighbors John Deere and one of the disc that hold the spoons had broken and been rewelded to the shaft. The spoons themselves seem OK. Even if they break, I can reweld pretty easily.
JJ, I do have a welder and if I make a fixture to hold the spoon at the start welding, I think the welding would be easier. I am not a trained welder, but this may not be too critical.
Thanks for everyone's comments. I would like to find out someone's experience with the spoons. Also do I need wheels? I am leaning away from then, but will do it if necessary.
Bob Rip
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #26
I looked at a picture of the PT plug aerator. It looks like the spoons bolt on. Also there is a shield over and behind the spoons, I am guessing to protect the driver from plugs flying out. I could not seem to attach their picture but you can find it at power-trac.com under products then attachments.
Bob Rip
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #27
Yes, the spoons are bolted on for replacement as needed. Also each has a seperate zerk fitting which is a real plus.
I have many hours on my core aerator and can only say that it is a very fine attachment. Works best if the soil is a little moist for discharging the plug.
PJ
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #28
Does the grease going into the zerke fitting help release the dirt plug or something else?
Bob Rip
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #29
Have you had to replace any spoons yet after many hours?
Bob Rip
   / SPIKE AERATOR VERSUS PLUGGER CORE AERATOR #30
The grease goes into the spindle not the spoon.
No, so far all spoons are in very good shape. Just prior to use I take a long handled screw driver and clear each plug from dirt.
PJ
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53485)
THIS WILL BE A...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
UNUSED FUTURE SE61-61" HYD SWEEPER (A57193)
UNUSED FUTURE...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52707)
2018 CATERPILLAR...
2017 Chevrolet Sonic Premier Sedan (A55853)
2017 Chevrolet...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
