Posthole Digger Speed to run post hole digger
   / Speed to run post hole digger #11
Pole depth depends upon the height of the pole. 2' depth is ok for an 8-footer, but too shallow for most others. I haven't looked it up, but I believe 25-30 percent of overall length is the recommendation.
   / Speed to run post hole digger #12
Man, OH, man - I've got enough concerns/problems with the pto driven equipment I already have/use. I'm sure glad I don't use wood posts and need an auger. I'll let all you guys have the fun. I'm 100% T-133 posts on my fence line. And I use a manual pounder for that mile and a half of fence line I have.
   / Speed to run post hole digger #13
We screwed an eight inch auger into our clay soil, and it took a giant pipe wrench with a ten foot extension (and an hour's wasted time) to unscrew it. If it had gone much deeper (and when it threads into the ground, it goes quickly!) I would have had to backhoe it out. Gotta keep it cutting, and often it's a slow speed and light feed, "following" the cut rather than pushing it, that works the best.
   / Speed to run post hole digger #14
Gulp! :eek:
I ask this question on every post ole digger (PHD) thread, but no one has ever tried it (or answered): Cant you just use the pipe wrench or a bar on the PHD's PTO shaft, and use the PHD's gear box's ~4:1 mechanical advantage to back out the auger using a lot less force?
   / Speed to run post hole digger #15
Gulp! :eek:
I have seen several people mention doing that in threads. I don't really know, as I have never used a PHD. Well the PTO driven ones anyway. Dug plenty of post holes the hard way.:)
   / Speed to run post hole digger #16
Gulp! :eek:
I never thought of it, but it may not have mattered if I had. Augurs are relatively cheap and widely available, and I can always weld on a new shaft (which it needs, and still hasn't gotten); gearboxes and PTO shafts, perhaps not so much "home repairable", they'll cost actual dollars (though the whole digger was maybe $400 or so). I have thought that "reverse gear" in a PTO would be nice, however. But engaging the clutch on something known to be stuck would be a heart-pounding exercise.
In this case, I turned the tractor around to try to pull the augur out with the FEL (utter failure, with more than a ton of lifting force!)
   / Speed to run post hole digger #17
Gulp! :eek:
Yes I have done it that way. Its slow going but worked when I could not do it the other way. However I put the wrench on the U joint at the head of the auger and not the PTO shaft. One other thing in digging is drop the 3PT very slowly (a notch at a time) as you go. This should keep it from getting stuck as easily. I also spray paint a line on the auger for how deep I need to go
Got it put together and dug some practice holes Saturday. Worked pretty well, I just need more practice keeping the hole straight. :)
   / Speed to run post hole digger #19
I agree with all of the "use a slower speed" posts. PHD speed depends upon tractor PTO HP, ground condition and gear ratio of the PHD mostly, I think. If you drill enough holes, especially in hard ground, you most likely will get it stuck. I tried various tips from TBN including using a 48" pipe wrench. I even had to attach a chain to a pipe wrench on my first "stick" and driving the tractor in a partial circle a few times to get the auger starting to back out. Was really stuck badly with the flights having large rocks jamming them in place I think.
My ground is very hard clay and rocks- big rocks. I figured out a better way of backing out the auger on my property and that was to simply, gently, back the tractor up a couple inches and move it forward a couple inches- back and forth a few times while trying to lift the PHD using the 3PH lift lever. In a few minutes the hole will have loosened/enlarged enough to free the auger. Think of trying to remove a loose tooth when you were a child. Same concept and works great for me with little effort expended. I emphasize the word "gentle". My PHD is an ETA using the HD SpeeCo augers.
   / Speed to run post hole digger #20
Gulp! :eek:
I have used a long (4') bar stuck through the U joint. I had to replace a zerks fitting that I broke off, but other than that it worked great! You get the gear reduction working in your favor. Only took me about a half hour to get back to work.
Take it slow and good luck!
Jim
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2023 yamaha (A55758)
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
ex mark (A55973)
ex mark (A55973)
