Gary_in_Indiana
Elite Member
- Joined
- Apr 22, 2002
- Messages
- 3,373
- Location
- Fort Wayne, IN
- Tractor
- John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
I just hooked up my Speeco Quick Attach and then went to hook up my King Kutter 60" rotary cutter - no dice! I then tried pointing my hooks inward - too narrow then. I then took off the the upright arms and attached them to the inside of the mower deck brackets after queezing them together with a ratchet strap. Well, after all of that I have maybe 1/2" to play with when backing to hook up. I'm thinking of compressing them a bit further together and just using longer bolts and some washers or extra nuts as spacers to make the connections to the mower deck brackets. Does anyone see a problem with that?
The next problem was the top link connection. The first part was that I have a "U" shaped piece with a small block welded to one edge of the base of the "U" that is nowhere mentioned in the King Kutter manual. I figured out a way to hook it up that seemed to make sense but have no way of knowing if it's right or not. The way I have it on it doesn't seem to work right with the quick attach, but nothing else does either at this point. /forums/images/graemlins/mad.gif
I'm about at my wits end here. Does anyone else use the Speeco quick attach with a five foot King Kutter? How do you have your KK set up? Any chance of a picture or two of your top link set up? Thanks! /forums/images/graemlins/smile.gif
