SPEECO POST HOLE DIGGERS
/ SPEECO POST HOLE DIGGERS #11
I sold a lot of them. I never had a single complaint. But be sure to watch your bolt grade when replacing/changing the augers.
/ SPEECO POST HOLE DIGGERS #12
Those codes are always overkill. Around here we have to go 38" and I've yet to hear of frost more than a foot deep.
Jake,
Thanks for your comments.
My neighbours have a fairly sizeable cattle operation next to me. They also grow their own hay for winter feed. They have several pole buildings - most of which they built themselves. They have only gone down with their PHD and maybe a little more by hand (heavy bar, hand PHD digger etc) and as far as I can remember, they haven't had anything move - though some poles have rotted out under ground (fair amount of clay in ground).
The reason I want to put in concrete pier/pads is because of heay clay (but firm) around my place. I have attached the local code requirements for anyone that is interested. These are for the city area - I am 45 miles from the city and on 150 acres. I am pretty sure what I will be doing will be fine - I want to make sure that I only have to do the job just once. Obviously I want to do it right - without going overboard.
We get temperatures down to minus 40C/F - the coldest I have experienced so far in six years, is -37C. I know my septic tank and lines are buried 4ft down and I have had no problem (yet) from the cold.
Anyway, thanks for any and all comments - I am always happy to learn something new.
Cheers
Jim
  • circular_pillar_pad_support.pdf
/ SPEECO POST HOLE DIGGERS #14
I'll freely admit that I'm not a fan of 3PH PHD's, and if you have heavy clay soil and you get an auger stuck in one, getting it back out is a royal PITA since the auger is not reversible using PTO power. Don't ask me how I know.
I'd suggest you rent a skidsteer with a hydraulic powered auger as they are reversible.
/ SPEECO POST HOLE DIGGERS #15
***AMEN***
I bought a Speeco bit for an old PHD I had from my dad. 9" or so bit. Sucker bit...in the clay we have in north central Texas and that was it...on a 65 HP old Case it pulled the rear of the tractor down until it bent the stinger/support bar to the tractor. I have used a pipe wrench and a cheater pipe about 5 feet long *several* times to unscrew that sucker from the earth. I finally removed one carbide tooth from the bit and replaced it with a worn out POS to cut down on it grabbing like a cork screw.
Blech!
--HC
/ SPEECO POST HOLE DIGGERS #16
Since the subject has come up, can the flow be reversed on a 3PH PHD ? :laughing::confused2:
I would make the assumption that it can not because of the vanes (sp) in the drive but it would be nice... :thumbsup:
GENIE S-60 MANLIFT (A60736)
GENIE S-60 MANLIFT...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2019 Chevrolet Express Van, VIN # 1GB0GRFP7K1370206 (A61165)
2019 Chevrolet...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2010 BOBCAT TOOLCAT 5610 UTILITY WORK MACHINE (A59823)
2010 BOBCAT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
