Specs on BX22
/ Specs on BX22
I am more interested in the specs on the loader and backhoe, eg. breakout forces, lifting capacities, weights, etc.
-Dave
/ Specs on BX22 #3
BX220D
4wd
E-TVCS, liquid cooled 3 cyl diesel
Engine Kubota D905-E-BX
Gross HP 22
PTO 16.7
Displacement 54.* (898)
Radiator Fan Reverse air flow
Fuel Tank 5.5 gal
Tranny HST Hi-Low 2 for 2 rev
Diff lock Standard
Drive 2 and 4 selectable
Brake wet disc
PTO live independent hyd clutch
rear 540 rpm @ 3068 engine rpm
mid 2500 rpm @ 3125 engine RPM
PTO select mid only, rear only, mid/rear simultaneous
Hyd pump 5.5 gpm
3 pt. lift 1210 lbs
24" behind 680 lbs
steering hydro PS
Dimensions 92 w/ 3pt
width 45.1
wheelbase 55.1
grnd clearance 6.7
min turning radius 32.2
weights w/ ROPS 1300lbs
(dimensions are in inches
/ Specs on BX22 #4
Backhoe Model BT600
Digging force using bucket cylinder lbs/N 1936/8610
Digging force using dipperstick cylinder lbs/N 1137/5050
Boom swing mechanism One cylinder
Net weight (Approx.) lbs/kg 617/280
Transport height in/mm 61.9/1575
Loading height in/mm 64.4/1635
Digging depth, 2ft. flat bottom in/mm 72.4/1840
Swing pivot to rear axle center line in/mm 28.6/7250
Reach from swing pivot in/mm 97.8/2484
Bucket rotation deg 180
Swing arc deg 140
Loader specs LA210
Maximum Lift Height in/mm 70.1/1780
Clearance w/Attachment Dump in/mm 51.2/1300
Reach @ Maximum Height in/mm 29.9/760
Maximum Dump Angle deg 45
Reach w/Attachment on Ground in/mm 51.6/1310
Attachment Rollback Angle deg 25
Digging Depth (when bucket is level) in/mm 3/75
Material Bucket Width in/mm 48/1220
Lift Capacity (Bucket Center) lbs/kg 460/210
Breakout Force lbs/N 845/3750
Raising Time/Lowering Time (w/o load) sec 2.9/2.9
Attachment Rollback Time/Dumping Time sec 1.5/1.4
Marie
2022 INTERNATIONAL MV607 S/A 26FT NON CDL BOX TRUCK (A69167)
2022 INTERNATIONAL...
213086 (A64276)
213086 (A64276)
2012 JOHN DEERE 700K LGP CRAWLER DOZER (A65056)
2012 JOHN DEERE...
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
x (A68191)
x (A68191)
