Specs on BX22
   / Specs on BX22
I am more interested in the specs on the loader and backhoe, eg. breakout forces, lifting capacities, weights, etc.
-Dave
   / Specs on BX22 #3
BX220D
4wd
E-TVCS, liquid cooled 3 cyl diesel
Engine Kubota D905-E-BX
Gross HP 22
PTO 16.7
Displacement 54.* (898)
Radiator Fan Reverse air flow
Fuel Tank 5.5 gal
Tranny HST Hi-Low 2 for 2 rev
Diff lock Standard
Drive 2 and 4 selectable
Brake wet disc
PTO live independent hyd clutch
rear 540 rpm @ 3068 engine rpm
mid 2500 rpm @ 3125 engine RPM
PTO select mid only, rear only, mid/rear simultaneous
Hyd pump 5.5 gpm
3 pt. lift 1210 lbs
24" behind 680 lbs
steering hydro PS
Dimensions 92 w/ 3pt
width 45.1
wheelbase 55.1
grnd clearance 6.7
min turning radius 32.2
weights w/ ROPS 1300lbs
(dimensions are in inches
   / Specs on BX22 #4
Backhoe Model BT600
Digging force using bucket cylinder lbs/N 1936/8610
Digging force using dipperstick cylinder lbs/N 1137/5050
Boom swing mechanism One cylinder
Net weight (Approx.) lbs/kg 617/280
Transport height in/mm 61.9/1575
Loading height in/mm 64.4/1635
Digging depth, 2ft. flat bottom in/mm 72.4/1840
Swing pivot to rear axle center line in/mm 28.6/7250
Reach from swing pivot in/mm 97.8/2484
Bucket rotation deg 180
Swing arc deg 140
Loader specs LA210
Maximum Lift Height in/mm 70.1/1780
Clearance w/Attachment Dump in/mm 51.2/1300
Reach @ Maximum Height in/mm 29.9/760
Maximum Dump Angle deg 45
Reach w/Attachment on Ground in/mm 51.6/1310
Attachment Rollback Angle deg 25
Digging Depth (when bucket is level) in/mm 3/75
Material Bucket Width in/mm 48/1220
Lift Capacity (Bucket Center) lbs/kg 460/210
Breakout Force lbs/N 845/3750
Raising Time/Lowering Time (w/o load) sec 2.9/2.9
Attachment Rollback Time/Dumping Time sec 1.5/1.4
Marie
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A52748)
2017 Ford F550...
