Spec's of the a 200CX loader on a JD 2210?
   / Spec's of the a 200CX loader on a JD 2210? #21
Re: Spec\'s of the a 200CX loader on a JD 2210?
I don't care what your dealer said, maybe he should get out in the field and do some work with the loader. I moved 27 loads 3500 lb mix concrete with over 800 lbs of rear ballast. I'm being very conservative on the weight in the bucket but I bet it was well over 800 LBS.
   / Spec's of the a 200CX loader on a JD 2210? #22
Did a little research on how much the 200cx loader sticks out in front to the 210 fel. My father in law has a 2210 with 210 loader. If the 200cx is longer I couldn't see much difference, it's sure not 12". If anything a couple inches, if that. Here's a photo of my 200cx loader. You 210 loader guys tell me if you see a difference.
I'm not doughting you . I was just curious because my dealer said the 200CX lifts about 150 LBS more than the 210 according to him, But some of the spec's here are coming up short in favor of the 210. That is why I was asking.
Thank You
Jim
   / Spec's of the a 200CX loader on a JD 2210? #24
Not sure which loader will lift more. Wouldn't want to lift much more. My feeling is if your going to start lifting 800 lbs or more, you need a bigger tractor not a 2210. Just for the stability factor.
   / Spec's of the a 200CX loader on a JD 2210? #25
Lobo,
What are you comparing in this pic? What is that other tractor behind the 2210? /forums/images/graemlins/confused.gif
   / Spec's of the a 200CX loader on a JD 2210? #26
I still don't think we have any printed source from Deere that gives these specs right? Is it that they have somthing to hide? Sure seems fishy since they are so forthcomming with other information.
   / Spec's of the a 200CX loader on a JD 2210? #27
Not comparing the 650 & 2210 in the photo. This was the only pic I had on hand of my 2210 with the 200cx loader attached. Is your 210 loader closer to the front then the 200cx in the pic? Like I said when I looked at my father in laws 210 loader, I couldn't see much difference in distance.
   / Spec's of the a 200CX loader on a JD 2210? #28
I think it is because of all the new models and combinations that the spec sheets have yet to catch up, but here is a little more I have been able to find out:
Specs for a 210 loader on a 2210: 640 lbs lift measured at the pivot pin. Breakout 1565 lbs at same point. Lift height 68.5". Rollback angle 26.5 degrees and dump at 47 degrees.
Specs for a 200X on a 2305: 562 lbs at pivot pin. Breakout 1513 lbs. Rollback angle 31 degrees and dump at 39 degrees.
Specs for a 200CX on a 4110: 800 lbs at pivot pin. Breakout 2137 lbs. Rollback angle 25 degrees and dump at 38 degrees.
So the 200CX loader with the 7.4 gpm of the 4110 will lift that 800 lbs. The question is what that loader will do on the 2210 and the 2305, which is still unclear as to the flow rate.
I think the engineers at Deere are enjoying this all -- afterall -- look at how much interest this post and the SHHHHHHHHHHHH one about the 2305 have garnered. /forums/images/graemlins/smirk.gif
   / Spec's of the a 200CX loader on a JD 2210? #29
Stoneham's has a spec sheet up on both the 2210 and 2305:
http://www.stonehams.com/2305.html
Here are a few quick diferences I spotted:
2210: 39.5 ft. lbs of torque; 5.5 gpm pump (3 main, 2.5 power steering); 3PH lift 700# at 24"; 5.0 gal fuel; 86 dba; 1400 lbs weight.
2305: 41.7 ft. lbs of torque; 5.2 gpm pump (2.9 main, 2.3 power steering); 3PH lift 681# at 24"; 5.5 gal fuel; 83 dba; 1450 lbs weight.
There are other differences, but these are a few I picked up on. /forums/images/graemlins/smirk.gif
Giyi 72"  Grapple (A57149)
Giyi 72" Grapple...
2020 DRAGON ESP...
Case 621D (A57148)
Case 621D (A57148)
BEFCO 10 WHEEL V-RAKE (A52708)
BEFCO 10 WHEEL...
Kivel Pallet Forks (A57149)
Kivel Pallet Forks...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
